Which winch hook/shackle do you guys recommend.
CavFab_mfg
Summit Sponsor (Level 3)
CavFab
Wildwood ga
2018 jlur
Aftermarket Jeep Product Manufacturer
F55 flat link or ultrahook (prefer the latter).
I will die on this hill.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
I like the versatility of the Ultrahook. Depending on the situation, it can be used with either soft or steel shackles or hooked and latched to both rope and strap baskets.
CodyW
Cody
Arizona
GX470
I do the same. The soft shackle I use is a well used one I found on the trail. Since it’s constantly exposed to the elements I won’t use it for actual winching, I have another 4 or 5 fresh ones I can use.
I attended an off-road recovery class and they were big proponents of eliminating as much metal as possible. They are also fans of roller fair leads, even for synthetic rope, because it reduces friction on the rope.
How do you connect the soft shackle to the end of your winch line without it being doubled up? Did you make a brummel loop at the end of your winch line? Thanks, from a winching newb. :)
Steph1
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Soft shackle are a ball in a loop. Here, a picture is worth a thousand words.
Jeep Wrangler JL Which winch hook/shackle do you guys recommend. D1F8B2E4-DB21-47D8-806E-3A40AF0BC918
rdfact
Ron
Nevada
'21 JLURXR, '01 WJ
My winch rope still has the metal loop/eye at the end like this.
Jeep Wrangler JL Which winch hook/shackle do you guys recommend. 9E9DE445-C9EA-4043-9FF2-171B2E12D2AB
Beachcomber72
2022 JLU High Tide
I'm a fan of the winch thimble fan myself, but I run a knock off $20 amazon special.
I’ve said it a million times before and will repeat it…
Cheap Amazon or elsewhere recovery gear can/will definitely badly injure you or kill someone. Never skimp on recovery stuff!!!
ArcadeTracks
PJ
Pittsburgh, PA, USA
The tool in the video is called a fid. Everyone with synthetic rope on their winch should carry one in their recovery gear. If Factor 55 makes anything worth its price, it's their fid. It's a unique fid in that it incorporates a wire chinese fingertrap like some electrician fish lines. But in a pinch, you can use a stick you whittled to a point or a Bic pen, and some tape.
Looks very similar to a lot of (baseball) glove lacers I've seen
CodyW
Cody
Arizona
GX470
Thanks. I am familiar with a soft shackle, but didn't think it would be able to roll up into the winch while in a closed loop like the example in the bottom right of your image. I was assuming it would have to be like the example in the bottom right, so it wasn't doubled up going into the fairlead, but somehow connected at the loop end of the soft shackle to the end of the winch line.
But it sounds like the soft shackle is just being connected like the example in the bottom right.
Thanks for the input!
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
I used to attach my SS to the metal eye loop but then I discovered under high load the SS has a very small radius and the eye started to flatten. I now use a 7/8" D-ring there. Normally I need the D-ring on the end anyway.
STW
2022 JLR 2door 2.0T Rubicon stingrey
I'd remove the metal eye loop from my winch line end-eye if I could. And keep the splicing it has. I could cut and re-splice but that's a waste.
  • Like
Reactions: J0E
Rubi6mt
Nj
2021 JLUR 6mt
Ultrahook for me so I can go either way. When turtled on a boulder at Crawl Daddy, the hook part of the ultra hook was great for the quick bump I needed to get off the rock
Jeep Wrangler JL Which winch hook/shackle do you guys recommend. 20230310_143809
  • Like
Reactions: J0E
Steph1
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
Any idea how much I hate you with the AEV bumper…. I mean damn…. Unfortunately can’t justify the expense…
Jeep Wrangler JL Which winch hook/shackle do you guys recommend. C65ADB83-C467-449E-97F9-ABE309AE8BD2
Rubi6mt
Nj
2021 JLUR 6mt
Awesome Jeep! As long as you run it and enjoy it ?.
Some pic of the trail I got turtled on:
Jeep Wrangler JL Which winch hook/shackle do you guys recommend. 4347AFFE-E857-4D68-84D2-1BF63C8FF812
Jeep Wrangler JL Which winch hook/shackle do you guys recommend. 20230311_123710
Jeep Wrangler JL Which winch hook/shackle do you guys recommend. 20230311_124609
jbcrane
40.5853° N, 105.0844° W
Just a Jeep, M'am.
3D Animation
I went with the WARN Sidewinder - black. I had a nice, red ProLink, but my wife said it looked like a dog's (ahem...) b*ner on the front of the Jeep. I couldn't unsee that... and went with something a little less... exciting.
