rbkat
- Rees
- Apr 4, 2021
- Dallas, TX
- 2021 Jeep Wrangle Rubicon
Happy 4th of July...
2021 JLUR with steel bumper. Today, installing Oracle rear bumper backup led lights.
1. Even with the rounded corners had to grind the left (driver's) side light and pound the steel bumper to get the light to fit without cracking it. Grind...fit....grind some more....fit...grind/pound some more...repeat many times until a fit is achieved. Extremely poor fit on left side. Finally got it in....then the wiring.
2. Bought the Oracle harness mentioned in post #542 above. The male part will not lock into the OEM tail light. I suspect it is due to pin holder not being fully recessed into plug because of oversized wires (white). Very poor quality control. Do no buy this harness until it is revised. I am still in process of wiring installation and am deciding whether to duct-tape the Oracle harness to the OEM plug or wire directly using with Posi-Taps.
3. Wires on harness are not right length. You'll have excess wire on one side and too little on the other.
This installation is made harder due to insufficient research by Oracle.
As to fit, probably fine for plastic bumper.
