Rear Bumper Integrated LED Reverse Lights
rbkat
Rees
Dallas, TX
2021 Jeep Wrangle Rubicon
Happy 4th of July...
2021 JLUR with steel bumper. Today, installing Oracle rear bumper backup led lights.
1. Even with the rounded corners had to grind the left (driver's) side light and pound the steel bumper to get the light to fit without cracking it. Grind...fit....grind some more....fit...grind/pound some more...repeat many times until a fit is achieved. Extremely poor fit on left side. Finally got it in....then the wiring.
2. Bought the Oracle harness mentioned in post #542 above. The male part will not lock into the OEM tail light. I suspect it is due to pin holder not being fully recessed into plug because of oversized wires (white). Very poor quality control. Do no buy this harness until it is revised. I am still in process of wiring installation and am deciding whether to duct-tape the Oracle harness to the OEM plug or wire directly using with Posi-Taps.
3. Wires on harness are not right length. You'll have excess wire on one side and too little on the other.
This installation is made harder due to insufficient research by Oracle.
As to fit, probably fine for plastic bumper.
ORACLElights
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
Hi Rees, thanks for your feedback. We understand that you are seeing different fitment on your metal bumper. Our Rear Bumper LED Reverse Lights for Jeep Wrangler JL are designed to match the factory plastic bumper, and we did add the beveled edge for an easier install on steel bumpers. However, additional modification may need to be done for a perfect fit on your particular steel bumper. This is listed on the product page or you can find the instructions HERE.
If you would like to speak with a representative regarding any of your concerns, please feel free to PM us or give our team a call 1-800-407-5776.
rbkat
Rees
Dallas, TX
Thanks, Oracle for the reply. Regardless of my squawks, I do like your backup light.
One other hiccup...after wiring directly to one tail light (abandoned the Oracle harness). I was not getting electricity to the backup lights...OEM's and Oracle's. After checking and checking my wiring, I remembered the chain about loose fuses. Opened the fuse box, found over a dozen fuses and all relays loose. After pressing them in place (you'll hear a click), voila...the backup lights worked!
I'm done with my installation and I do really like the lights.
Emt347207
Staten usland ny
2021 jlu 4xe sahara
Question, has anyone used this harness on led tail lights with the blind spot sensor? If yes, does it work and or cause errors in the system?
JP_Oracle
JP
ORACLE Lighting
Yes, this will work with no issues!
Emt347207
Staten usland ny
2021 jlu 4xe sahara
So i tried to do it this weekend. The harness connection to the taillight itself is to long. The clip did not snap back on. So i will be making a 7 pin harness to accommodate this issue so it will not potentially wiggle loose over time dusconecting the taillight. I will post pictures of the completed project as i get time. Thanks for the super fast responses everyone.
Slowpoke
Columbus, Ohio
22 Mojave & 22 Sport
Yes
What is everyone doing for reflectors once you install the new backup lights? I've purchased the lights AND the additional harness. I like where they fit in the bumper and it's a nuce clean functional look. I have factory LEDs and there are no reflectors in the taillights. I purchased these in December and I'm hesitant to install them because of the lack of reflectors. I'm "pretty sure" reflectors on the rear are required by law, I could be wrong? I don't want to glue on Walmart reflectors. Any ideas?
Murphydog
Seattle
2020 X3M, 2023 JLUR XR
can't wait to see your pictures - thinking about adding these and I too have LED tail lights.
AnnDee4444
'18 JLR 2.0
How about some sort of reflective hitch plug?
FWIW, I think many license plates are reflective also.
rockadile
PA
2019 Mojito! JLUR
Reflective stickers on the bumper? You can even get them in black.
Pepe My Little Mule
J.D.
Pennsylvania
98 Jeep 4.7L; 2020 Jeep Wrangler Unlimited Willys
My tail lamps reflect light just fine, even LED's.
