AnnDee4444
Here's a spreadsheet I built to calculate gear ratio, tire size, speed, etc. The yellow colored cells are how to control the inputs (either drop-down or number fillable), all other cells are un-editable.
Update: Added a new tab to easily compare differential ratios in top gear. Also some slight changes to the input methods on the other tabs.
11/25/20 Update:
12/1/20 Update: Added ability to compare two scenarios
12/8/20 Update: Added Axle Torque by Gear calculator
11/25/20 Update:
- Combined the automatic & manual tabs
- Added an option to input the revolutions/mile
- When inputting tire diameter, the effective rolling diameter is now calculated at 97.1%.
