3.6 power loss at elevation
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
So in summary, the OP felt power loss as they went higher. This has then been argued back and forth about what they felt, being substantial enough to be felt, even though they felt it, by people who weren't there for about 12 pages.
JeepinJason33
Denver
2021 JLUR, 2021 GCL, 1997 TJ, 1983 Chief FSJ
You're arguing you have to test these 2 engines like they are unique? It's accepted, tested millions of times, and the formulas exist for that reason. Both automotive and aerospace engineers have tested, verified, and agree that the formulas are accurate. I don't care if you believe it any more than I care if you believe 2+2=4. It is fact that an NA engine loses 3× the power period.
You must test two engines to get the exact HP, yes that is what I am saying. You stated that you would have 50 hp more than a 3.6l at 10,000'. 2+2=4 has been proven. The 50 HP difference between the 2.0 and 3.6l at 10,000' has not been proven. Again, it could be 50, but there is no data that proves it is 50. Only data that shows assumed losses, not the losses of these two engines at 10,000'. And yes again, to prove it is any HP, you have to take the same two engines at sea level and then test those same two engines at 10,000'. That is how you prove out your theory. Please, don't take my word on any of this, show this thread to any scientist, scholar, engineer, etc. and get their view on the difference between opinion, theory, and fact.
Now you are stating an NA engine loses 3x the power period. Same thing you have done in every reply, change the original statement and make up another unproven statement. Not every turbo is the same so not every turbo engine is going to have a 3x advantage. But that is OK, you keep believing whatever you want.
You can also have the last word, I am done. The amount of BS that you state and then completely changed the topic once someone shows that you were wrong instead of just leaving it alone or admiting you had your facts incorrect, is ridiculous. You clearly don't understand the difference between a fact and an assumption or even real world data as you have spewed so many wrong points over these 12 pages that it is hysterical to anyone else reading this other than you.
Have a nice night.
CarbonSteel
This whole thread would be non-existent if the 3.6L made 310-330HP and 400-420lb-ft of torque instead of its Singer sewing machine numbers.
Laughable that Stellantis continues to state the 3.6L is the "stalwart" of the Wrangler line.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
Have a nice night.
Hopefully you realize that when someone tests a vehicle or engine on a dyno they adjust the numbers based on altitude as well as climate criteria. And that the equalization adjustments used for forced inducted and naturally aspirated engines are significantly different.
They do not take the engines to various altitudes to test them. Those multipliers are already known and verified.
2nd 392
Ca
And any 2 dynos don’t necessarily show the same numbers, their could easily be a substantial difference between the indicated numbers of the sea level one and the 10K ft one invalidating the results. The percentage difference would be similar but not exact, the same percent drop of the higher powered one would be a higher number.
mfg’s don’t dyno every engine produced to verify numbers, the same vehicle with the same drivetrain are sometimes a Dog, or a runner compared to the average.
Remorseless
NC
Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Not Only The Guy Who Defines What A Jeep Guy Is, But Also The Guy Who Defines What A Jeep Thing Is, Guy Who Has The Authority To Do That
Remorseless
NC
Out of curiosity, what's your experience with the 4.0 (or 4.2 or 2.5/2.4) and 3.8 that were in Jeeps previously?
JeepinJason33
Denver
Yes, they can adjust the air to fuel ratio at any altitude. Does not change the fact that there is not a current dyno sheet with testing for 10,000’ for the 2.0 and 3.6 on the same dyno to back up his claim of 50 hp difference.
Ratbert
PNW
Software Engineer
I'll quote you to make sure we have a history of what you just said.
Are you under the impression that nothing is real until all possible combinations are tested? That we can't use all the previous tests to get an accurate approximation of reality?
Remorseless
NC
Stoichiometry doesn't exist
Remorseless
NC
