AnnDee4444
I have OEM Rubicon suspension with the Mopar Lower control arms, and caster is right around 6°.Now that just seems silly to revise the alignment requirements just so you can make spec....I wish I could do that at work haha. I understand it's a cost saving thing, but I would also think they would be concerned with making it right.
Do you know the caster angle on the sport and Sahara?
So you put the Mopar lift on yours but didn't change the LCA's? What is your caster angle?
JL Alignment specs: https://www.jlwranglerforums.com/fo...heel-alignment-specs-toe-caster-camber.17832/
FWIW, here are the specs of other Jeeps with straight front axles (all around 7° of caster):
