- Oct 7, 2019
- Metairie, LA
- Website
- www.oraclelights.com
- 2019 Jeep Wrangler JL
- Occupation
- Automotive LED Manufacturing
Technically you are running the wire up not dropping it down but yes, its basically accessible as you describe. You could drop a string down and pull the wire up with the string or have a helper hold the wire while you pull it up from the tail light cavity.So if you take the taillight out, it should just drop down in-between frame/skin hollow area? Guess I could just. take it out and look inside. Looking from underneath could see too much.
