XR observations
Mocopo
Arizona
Huh? It's not in need of a "fix", or a recall. It's designed that way.
What they should recall are swimming pools. Everyone I know that goes swimming, gets all wet!
But they're designed that way!
Illinois
99tj 21 2dr willys sport, 22 4dr willys sport XR
What puzzles me is that these clearances between jounce and pad are all over the place? I added my mopar steel bumper and warn zeon 10-S. It drooped 3/4 an inch. Put some Teraflex one inch spacers on today and I probably have almost four inches between the jounce and pad now?Have the 89 and 90 springs. First time I read the other day that mopar put the long tubes on with the 35's to satisfy the lawyers for tip over reasons?
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
Think about this, if you have a regular Rubicon/Willys - you will spend the money on the lift kit (1.5-2" min) to install 35s for off-road use
The lift is the only expenditure that is offset, for some folks rest of the XR package is still worth it, excluding the suspension lift (or the lack of it)
AnnDee4444
'18 JLR 2.0
They're to keep the tires from making contact with the fender. No manufacture can sell a new vehicle that would bottom out the tire in the wheel well.
Also I think everyone should start comparing shock eye-to-eye lengths at ride height. It's easier to compare to a standard JL suspension or other aftermarket options... just add 1-3/8" to the bump stop length.
191185
Troy
Minnesota
2021 JLUR 3.6 E-torque
The factory setup limited flex. As I started to wheel more aggressively I wanted more flex. Added a RK 2.5” lift and the flex improved a lot.
First pic….top is factory, bottom is after the lift
I have a stock XR, looking to get more flex as well ..
Is that the ONLY thing you had to do ? what all was involved with the RK 2.5” lift , did you have to mess with the bump stops or anything else ?
Did you replace the shocks ?
Jazzicon
Jasmine
Concord, North Carolina
2021 Rubicon Extreme Recon, 2021 Toyota
I replaced the shocks, if you don’t, you are still going to limit your flex. I’m running with no bump.
As far as the lift, it is very straight forward install. My build thread should be in my signature line if you want to have a look.
Hardest part was cutting the axle side LCA brackets with a hole saw….and even that wasn’t too bad.
onemoreokie
Frisco, CO
2022 Lexus GX460, 2021 JLU Rubicon XR
No real change to the ride dynamics (other than no more bottoming out).
Craiger was/is correct. A one inch spacer from Teraflex pretty much solves this problem. I just installed it and gained about 1 1/4 to 1 1/2 inches of bump stop space. Shock length is also 1.5” longer now. I just took all the bumps/dips around town that I’d bottom out on and it was just fine.
Am I still going to waste 5 grand and put a 3 inch lift on and some remote reservoir shocks…..yes. I want better flex on the trails.
Item number from Teraflex for the spacers is 1155100.
Jeep Wrangler JL XR observations 2047FC6D-A766-4710-B20E-A627821550A3
Jeep Wrangler JL XR observations 678BE917-D9BF-4CE7-B2A8-1800E455042E
ColoradoMike
Denver
2022 JLUR XR
Cool. But does this mean you will get tire rubbing fender when at full flex, swaybar disconnected, while rock crawling? I am just trying to understand all this.
onemoreokie
Frisco, CO
That’s a good question. I don’t really know. I’ll report back.
AnnDee4444
'18 JLR 2.0
If set up correctly, ride height won't have any impact on rubbing. The bump stops are sized to keep the tires out of the fenders (or the axle from contacting anything important). Bigger tires = taller bump stops. Also the 392 & diesel have a larger motor that requires longer bump stops to keep the axle from contacting something (oil pan?).
Spacers just adjust the ride height but don't change the up-down range of the suspension... that is dictated by the shocks. A shock's compressed length should be selected based off of the suspension's fully compressed length (sitting on the bump stops) to ensure that no shock stoke is wasted. Adding shock length will allow for more flex.
stumblinhorse
Maybe you are new to suspension components. But you really need to have bump stops. If you don’t you will destroy your shocks, if that is your compressed limiter. Shocks fully compressed is bad. The bumps saves your shocks. Add bumps to stop your shocks from blowing up.
Remorseless
NC
Nope, bumps set how close to the frame the axle can get - the minimum distance of a compressed suspension. That stays the same with a spacer lift or with a suspension lift. Bump stop is usually adjusted to keep from compressing too far - either for fender clearance, frame/axle/linkage clearance, or shock compressed length. With bump stops you're balancing all of this - how far up can I allow the axle to come, still clear the frame, not get into the fenders with the tires, and not bottom out my shocks. So, an example - assuming all is right with the world and you've got a lift with 37s and you need 2" additional bump stop height over a stock Jeep to clear everything, that same bump height would apply at a 2.5", 3.5", or 4.5" lift assuming the shocks were OK with it. That spacer mentioned by @onemoreokie is just adding uptravel by spacing your spring down (mimicing a lift spring), but leaving the bumps alone. So, same bump stop, same minimum compressed clearances given the same shocks and tires.
