Mopar LCA swap
Keycub
Paul
2020 rubicon
Curious as to people's opinion. Have a 2020 JL Sport S. Considering a Rubicon suspension with TF .5" spacers and the longer Mopar LCAs. What kind of lift should I expect? Considering 35s and wondering if it's enough. Probably used 90% as daily driver.
Should give you 1.5- 2 inches
cbrenthus
FL
'19 Mojito JLUR
I might be crazy but the site says the longer arms won't fit my 2020 JL? Any idea why? Is it because it's designed for lift kits?]
I'd bet the site just hasn't been updated for 2020 - I know of no differences. But, might not hurt to hear from someone with a 2020 to confirm ;)
^Beat me to it - I didn't read the rest of the thread
Keycub
Paul
2020 rubicon
They fit. Put my rubicon at 6.3 caster
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
Springs on the Rubicon suspension are 61,62 and 91,92. Highest combination I could find.
Should give you 2" easy.
I put on 60/61 + 91/92 with a 3/4" spacer. Got 2-1/2" up front and 2-1/4" in back.
Jeep&dogs
Jim
Cedar Lake
2020 JLUr
Just added these to a 20 JLUR today, stock height and 35’s on stock wheels. It drove fairly well prior but I would still say not as good as my Lj did. For the record I had a ton of time into the suspension and shock valving of the Lj and it didn’t “drive like a Jeep” I would say the longer arms have this one driving 95% as good as the Lj. Fairly happy with my $60 investment in these.
WireEdge
Jamey
Ann Arbor, MI
2018 JLU
I have a Rubi suspension on the way to me, and I want to order the LCAs. Are they the same part right and left? They don't look symmetric, but the site says two needed per vehicle. P/N 68322798AA. Does that seem right?
Edited to clarify: the Mopar lift LCAs.
Roky
Roky
They’re left and right and sold in pairs.
WireEdge
Jamey
Ann Arbor, MI
2018 JLU
Every site I am finding shows only one and says "two required, sold individually." Anyone know if there is a different part number for the other side then?
blnewt
New Mexico
Just ask @cosine he knows!
You need two, but they are the exact same part# for both sides.
Will_Jeep
Will
Atlanta
Black 2108 JKU Sahara, Black 2016 Mercedes CLS400
I just installed these, ordered from AllMoparParts, after adding a 2” spacer lift last week.
  • It took about 1.5 hours
  • I did it with my Jeep on the ground, no ramps
  • No power tools, 1/2” ratchet and pipe for leverage
  • 15mm, 21mm & 24mm tool were all that were needed
  • 190 ft lb is tight, so very tight, to undo
  • You need to undo the bolts, not the nuts, they grip (ask how I figured this out!)
  • My torque wrench topped out at 150lbs., then I gave it a little bit more, about what I felt it took to undo
I took it out for a quick test drive, and first impressions are favorable, it definitely feels better!
blnewt
New Mexico
Glad it worked out well, FWIW the SAE sized sockets fit tight, the 13/16" & 15/16 are a better choice as there's been cases (especially w/ the 21mm) of rounded heads. Jeeps are a mixed bag when it comes to fasteners, I always bring both SAE & Metric sets to all my Jeep projects as it's hard to get good fit on just one set or the other :( This also applies to the oil drain plug and oil filter cover, SAE sizes have no slop but the metrics do :(
