Lowered JL
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I’m mostly surprised at all the people encouraging this dude.
Are you thinking that we should all be sheep and never deviate from what's currently considered "normal"? I'm not a big fan of the idea, but to each their own.
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
Some of you need to get a grip; you're whining like the OP's JL is scraping the frame with cambered wheels. It looks like it sits about the same height as a stock XJ from 20 years ago. FWIW, here's my old XJ with 18" Magnum R/T wheels.
AnnDee4444
'18 JLR 2.0
dlong1119
Gainesville, FL
21 Sahara 4xe (StingGray)
dlong1119
Gainesville, FL
I'm still a little new to the Jeep mod world, but my understanding is that the only difference is springs/shocks for the Rubicon suspension, right? Since both of those are being replaced here, why would they spec that?
AnnDee4444
'18 JLR 2.0
They're either lazy & don't care, or misinformed.
This should exclude diesel, XR, 392, 4xe (basically anything with the tall bump stops).
dlong1119
Gainesville, FL
That was my thinking, thanks for confirmation. Not that I'm planning to do this, but I would assume the 4xe exclusion (and maybe diesel/392) would be due to just the weight, right? XR is the only one with taller bumpstop pads?
AnnDee4444
'18 JLR 2.0
I believe everything I listed gets the taller bump stops.
Weight could be an issue, but I suspect these spring rates are much higher than typical JL lift springs.
five9dak
PA
Bikini '20 JL Freedom, '99 Dakota R/T, '11 Boxster
OP I think you should add rubicon flares so you can cut those springs and go even lower. Then get "Low Altitude" badging made up.
Honestly - I have a lowered truck, and grew up in the 90s.
