Bumper & Winch Install Lowered Front
HighvelJL
Herb
coral springs
2024 JLU Rubicon
I have a 2024 Rubicon with Extreme Tire Package with 35" tires. Jeep came with plastic bumpers. I installed an aluminum/steel bumper and Warn winch and lost 1" - 1-1/2" height in front. Is it worth adding
a spring spacer to compensate? I don't want to do a lift.
jadmt
jeff
montana
I would. An inch is noticeable to me visually
CloakedWillys
Summit Sponsor (Level 3)
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
Sales and tech support for MetalCloak
A spacer would work. Other option is the stock winch package coils.
CloakedWillys
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
I anticipate the same issue soon - do you know the part numbers for those springs?
Nothing off hand on the coil part numbers. Might need to crawl under a jeep at the dealer that has he winch package. I swap out for lift coils. The 2.5" on the X package allows for a lot more travel.
PotterJLUR
Kansas
www.youtube.com
2024 392 Rubicon, RAM TRX, Camaro ZL1 1LE
The teraflex 1.5in leveling kit #1155300 would work great. It comes with 1in and .5in spacers that can be used together or separate. I just used this same kit on a JL at the shop that had just added a front bumper and winch and was about 1.5in lower in the front. I added the full 1.5in of spacers and it sits great now. (also the kit will come with 1in of front bump stop extension that will not be needed but it good to save for future use if you end up running larger tires)
Here is an amazon link to the kit https://amzn.to/4qFqdUj
Sportacus
Stephan
Empire
Wrangler JLU
Will the addition of spacers change the caster from where it was at stock? I would assume so but not sure.
WillysMeow
Corruptifornia
Bought my first new Jerp! :)
Bit wrassler
Good idea go crawl under and check the factory tags and take a picture. What do you mean by "The 2.5" on the X package"?
BUSHRVN
MONTE
ALBERTA
WRANGLER JLU SAHARA HIGH ALTITUDE 3.0
No if your just getting it back to the stock height that it was.
CloakedWillys
Will
Rancho Cordova, CA
www.metalcloak.com
18 JL 2.0T Sport S
I was referring to replacing the stock suspension with a 2.5" lift.
Aonarch
Mike Hawk
North GA / MT
'25 JLUR '41, '24 F-150 V8 4x4, '22 Mach 1 6MT
Motorsports Engineer
I installed OEM springs from a steel bumper/ winch JL and only lost 1/4" going with a Metal Cloak stubby and 12k winch.
Aonarch
Mike Hawk
North GA / MT
Do you happen to know part numbers?
I'll try to find them, but they are from a 392 XR Final Edition, so steel bumpers, 392, 35 XR package, winch, tow, etc.
