LCA
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
May I ask what is the LCA ? Long control arm ?
When and why is it needed ? I’m a bit new to “lift” kits. But not to suspension upgrades
ArmyRN
Paul
Longview, WA
1946 Willys CJ2A, 1998 Jeep TJ, 2023 Willys JLU
The "Mopar LCAs" you will often read about are a factory Mopar front LCA that is 1/4" longer than what your Jeep came with. They run around $65/pair (I got mine from Rock Auto). Nice upgrade and may help with your Jeep's alignment, especially if lifted a small amount (think 2" or less).
The Jeeps with the "XR" package (which I have) came with a factory 1.5" lift, and I later added a 1/2" spacer lift all around. The XR package did not come with the longer LCAs. I installed the Mopar LCAs before the spacer lift.
Million dollar question - can I tell a difference with the longer LCAs? No. I figure if I got an alignment done before and after the numbers would be better, but I thought it drove nice before I swapped them out. I figured "Can't hurt, might help, and doesn't cost much".
AC77
AC77
AC Abegian
Los Angeles
Thank you Sir and for not being sarcastic with your reply. I come from Drag racing background. This is my first lift / suspension mod start So some terms are a bit different than what I’m used to!
Now with that said. The Spacer lift you mentioned, Is that a body lift spacer ?
At this time the only “lift” I’ve installed is a Teraflex leveling kit. It’s been a nice ride. No difference in my daily driving. Looks just a touch higher (22 Sahara altitude diesel ) I’ve been doing a ton of research as to what will be a good lift for my driving style and once in a blue moon overloading and trails
AEV spacer lift. ($460~)
Mopar 2” lift
Or a AEV 2.5” lift
I’ve also installed fox 2.0 ATS damper
JKS track bar and Synergy sector brace
And last week Hellwig rear sway bar
And I love how it handles and drivers
DoI need/should also replace the front LCA’s ? Will I need to go longer LCA’s If I do a 2” or 2.5” ?
ArmyRN
Paul
Longview, WA
Mopar 2” lift
Or a AEV 2.5” lift
You're welcome.
It was a Terraflex 0.5" spring spacer lift all around.
You asked. Do you need to put in a pair of Mopar LCAs? No. Should you? I would. They're not expensive (~$70/pair), pretty easy to install, and can't hurt/might help.
A Mopar lift I believe comes with the Mopar LCAs as part of the kit.
Dynatrac also makes a well regarded 2" lift kit.
Left Field
Tim
Western WA
'67 RS-SS Camaro, 2021 JLUR392
I might add that if you put in the Mopar 2" lift I believe it comes with the longer LCAs.
If you go with a 2-1/2" AEV lift (Dualsport) it will come with front control arm geometry correction brackets that both restore the control arm angles but also have a cam plate to essentially extend the LCAs, negating the need for purchasing extended or adjustable ones.
LF
AC77
AC77
AC Abegian
Los Angeles
Thank you everyone. Some very good info
Appreciate you all !
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
Mopar 2” lift
Or a AEV 2.5” lift
I'm surprised you've never heard the term LCA. Almost every vehicle made has a lower control arm and it's usually called a lower control arm.
I'm not saying that out of judgement, just surprise.
AC77
AC77
AC Abegian
Los Angeles
we all just called it control arms front and rear , and in the shop as well, when i order parts, i always call it front or rear control arms, or on MBZ or BMW , they have various terms, the term LCA flew right over my head ,,,,
kah.mun.rah
Merenkahre Jr.
Duat
It stands for Life-Cycle Assessment. If you want to extend your life-cycle get adjustable LCAs. If you want to strengthen your life-cycle get HD LCAs.
OrneryBear
Charles
Central OH
23 Sarge JLUR 6spd
I mean if youre working on bmws that makes sense since they dont have an upper and lower control arm in the front and instead use a mcpherson strut in the front, but the rear has upper and lower control arms, and unless ya'll were just calling the upper a camber arm or something.
AC77
AC77
AC Abegian
Los Angeles
Im NOT working on a BMW -
