Caster Specification for the JL
Need some help here. Just had a teraflex 2.5 lift installed (their basic spring lift w/ sway bar end links etc) + Falcon ST2.1 shocks + teraflex geometry correction brackets (stock lca’s), falcon nexus 2.2 steering stabilizer. I have a steersmarts yeti adj front track bar and a rough country rear track bar ready to go on Saturday. Just had my alignment done (attached) and it drives like shit. Throwing me all over the road (slight exaggeration but something feels way off on steering).
I’m running 33in tires right now on method 17x9 -12 offset - plenty of backspacing.
Any ideas? hoping the adj track bars help but I don’t think that’s what’s going on here.
Just to baseline, have you had the TSB for the steering box done?
dginz
Dane
Towson, MD
2020 JLU Sport S
I haven’t and I know it’s not been done. bought this used w/ 58K mls now 60K mls- but steering felt totally fine at stock height w/ the new wheels/ tires.
I think putting that new front trackbar on would be worth doing first, just to eliminate it as a suspect, since you own it and it's a simple job to change out.
Roky
Roky
I’ve seen this happen several times….. different fixes on each one, but with that many miles, it can be bushings in the tie rod, drag link, track bar, control arms etc… it was driving ok until you lifted it because now there’s more leverage/ stress on these components and geometry change. …. Judging by your camber readings, first thing I’d look into is ball joints…Hard to diag without putting hands on it….get your track bars on and your axles centered up and see if that helps, if not you’ll have to just check everything out, process of elimination…..
Agree. The OEM balljoints on the JL are a short life component. Mine were loose around 20,000+ miles, with not much off-road and none of it hard. Just street driving back and forth to work and the store. The tierod and draglink end fittings are staked into the tube and are a possible loose connection.
AnnDee4444
'18 JLR 2.0
In addition to the ball joints, a 3" scrub radius is recommended for 2WD... and I'm pretty sure you're at roughly 3.25" (likely more if your tire is worn). Stock Rubicon is around 1"
Wheels with more positive offset, taller tires, or remove spacers (if you have them) will reduce the scrub radius.
Dg1615
Doug
Louisville
2022 willys
Help!! Can anyone interpret these numbers for me. First pic is bottom of right knuckle, second is bottom of left knuckle, third is off flat spot on pinion and I also used phone app on the two holes on front of diff which appear to be 1-1.5 degrees. How much caster do I actually have. Put new OME 2” springs on and the highway wandering is terrible. Is was perfect. Thanks edit, first and third are knuckles.
Jeep Wrangler JL Caster Specification for the JL 59E4C64B-6685-40E0-A45F-2E86CA3226E2
Jeep Wrangler JL Caster Specification for the JL B5EFEBDB-39B8-4F77-8B86-A43156E6B36C
Jeep Wrangler JL Caster Specification for the JL 8ABF9577-C4A1-46B8-9721-33017E06634D
Roky
Roky
The one on the diff, if you have to rotate it clockwise to hit 0 then you’re 1-1.5 less than 6 degrees caster, as 0 is 6 degrees….
Dg1615
Doug
Louisville
2022 willys
So I’m at 4.5-5. Time for some adjustable arms. Thanks. Bums me out this thing had awesome highway manners.
Dg1615
Doug
Louisville
2022 willys
Yea, I’m probably 1” taller then I was. (I had other springs in) Feels like I crossed the line with my ride height and need correction now. Classic Jeep highway wander. Thanks for the help
waveland
Charlie
tampa bay
2020 Sahara 4 door
I have read all of this thread and many others. Our 2020 JLU Sahara is my wife’s daily. It’s not lifted but has always had that wondering and sometimes flytie feel. We bought in new and it seams to have slowly gotten worse with time.
I just put new 275/70/18 Good Years on it and have an alignment appointment in a few days.
it appears to have excessive toe in by the old tire wear.
Do you think stock these could use a little more caster?
Thank you Charlie
JLUR Farout
M
SE Washington
2024 JLR X 35" Package
There was some good information in this thread. Thanks to those who shared their knowledge.
