Winch Shutoff Switch at Battery
JasonInDLH
JasonInDLH
Jason
MN
21 JLUR, 15 Yukon Denali
I’d Rather Talk Jeep’s!
Thanks for everyone’s suggestions and pictures as you all have given me great ideas.
Lots of you seem to use an Aux switch paired with a solenoid. I might go this route, but I’d have to add a Voswitch (as recommended) as all four of my OEM switches are used for lights (I got a lotta lights?).
AnnDee4444
'18 JLR 2.0
Terrymo
Terry
2023 JLURXR 3.6 ET
Th
Just to confirm, that's these parts:
What's the plastic material for on top of the accessory plate? Any idea how much room is between the hood & accessory plate?
The footprint of the Blue Sea Safety Hub 150 would make it hang off the edge of the bracket by about an inch on the edge nearest the battery. It was designed for a different size fuse panel as shown on the 813 website. I used a sheet of 1/4” ABS to make the surface of the bracket bigger. Without the 1/4” thick ABS spacer sheet I would estimate 2.25 to 2.5” between the surface of the accessory plate and the hood liner. I can get more precise measurements and better pictures if you’re interested.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
I run a solenoid and a Battery terminal fuse.
Every aux. power wire I install has a fuse in it.
I'd rather my plan to fail than fail to plan.
Nice set up!
Flip
Johnny
Virginia
I have a fuse located at the battery and a cut off switch for my winch. Do I need to install a solenoid as well?
Thanks
Yawnie'sPapa
Bill
Central Iowa
'22 JTO, '23 JLUR, '82 SX4, '73 P. Cardin Javelin
First time in 2020 -
Jeep Wrangler JL Winch Shutoff Switch at Battery 20201017_135923_HDR
Second time in 2022 Jeep -
Jeep Wrangler JL Winch Shutoff Switch at Battery 20220825_221501_HDR
As it sits now -
Jeep Wrangler JL Winch Shutoff Switch at Battery 20221109_160600_HDR
Jeep Wrangler JL Winch Shutoff Switch at Battery 20221107_162124_HDR
Yawnie'sPapa
Bill
Central Iowa
Thanks
No, the solenoid is just an electric cut-off switch. You can use either a manual switch like in my pic, or a solenoid if you don't want to open the hood and turn a manual switch.
Hope the fuse is a big one - a 12,000 pound winch can pull over 400 amps.
Flip
Johnny
Virginia
Your 2020 set up is basically what I have now except I have a sperate fuse at the battery. So the solenoid replaced the switch, yeah?
OK great, thank you
Flip
Johnny
Virginia
Can you recommend a fuse?
Yawnie'sPapa
Bill
Central Iowa
Sorry, I can't recommend one as I don't have a fuse for my winch.
The 200 amp fuse in the last picture is for my Western snow plow.
If I were to fuse my winch, I'd likely get a large fuse similar to what my plow has.
Flip
Johnny
Virginia
I was going to order a Blue sea system 300 amp fuse, The winch says max pull 300 amp. I think 300 amp fuse should be fine but I would have felt a little more comfortable with a 350 amp fuse, JIC.
Thanks for your help.
Terrymo
Terry
2023 JLURXR 3.6 ET
