Winch mounting plate
CJ-ING-RJ
CJ-ING-RJ
RJ
Iowa
18 JLUR, 73 CJ5, 07 Electra Glide
HEY thanks everyone for the response! Even though it is about 4 1/2 months after I posted the question.
I ended up going with the Rugged Ridge mounting plate, X20 winch, Warn hoop and line keeper. No complaints so far used 5 times. Easy breezy install (big garage and lots of tools).
Oh and I just drilled and tapped 1/4-20 threads into the steel bumper for the license plate mount. Super easy and a whole lot cheaper than the garbage products out there.
Jeep Wrangler JL Winch mounting plate 995B9F91-73C0-45AC-895C-265D47B4B26B
DHW
Atlanta
2018 Rubicon
Attorney
Another vote for Maximus-3.
The Good:
The Bad/Ugly:
  • Instructions were not 100% correct, wasted time assembling in wrong order. They have since come out with version 2 to fix these issues.
  • Minor modifications were needed
  • Very hard to access nuts/bolts with a Warn Zeon.
I agree the instructions suck. I followed the install video on their website. And that was the problem I was thinking of, not having to bend or cut anything, but the inner bolts being nearly impossible to get to.
D60
CO
JL
Sorry it makes you 'feel' that way. Look its up.
Thanks. I've been working with my counselor to find a safe space and as long as I go there twice per day and cry for a minimum of 2 hours each time I find my feelings are manageable.
I had tried to find evidence of these tabs and JL frame failure, but came up empty handed so I thought you might have some links or tech to support your position?
The .PDF install instructions are available here under the Technical Details tab and they only mention slotting a few holes, but no cutting
https://ruggedridge.com/winch-mount...-11543-16.html#product_tabs_additional_tabbed
Perhaps there's a second Rugged Ridge winch plate I'm not finding? This one does specifically say it'll work with JL factory steel bumpers
Sippican
Home
Jeep
Hopefully I didn't use up the full 2 hours, but I guess we all have different stress levels.
Here is the install PDS that says you need to 'remove' the bracket. When you actually take the bumper off you notice this Horn Bracket is a plate that closes the frame.
http://www.omix-ada.com/instructions/11543.16.pdf
Dealer said that if I have tracking problems, it could void the warrenty. Please apologize to your counselor for me.
Jeep Wrangler JL Winch mounting plate Screen Shot 2019-09-08 at 3.55.06 PM
D60
CO
JL
Wow, that red arrow appears to be pointing at air space, and they never used the term "cut" so it's impossible to know that's what they mean from reading the instructions.
Who's done this and experienced frame failure?
My counselor loves you, he's making $$$!
jimmyzwheelz
Jimmy
Little Rock, AR
2019 Wrangler Rubicon 2DR
The Good:
The Bad/Ugly:
What "minor modifications" were required for the winch plate install?
AnnDee4444
'18 JLR 2.0
Maximus-3
BRENDAN
Detroit,MI
www.maximus-3.com
2020 Gladiator Rubicon, 2018 JLUR, 2015 JKU
Aftermarket Specialists
Since the FCA design change of the skid plate brackets, we released the Gen 2 version of the winch plate that requires zero modifications to fit.
jimmyzwheelz
Jimmy
Little Rock, AR
Excellent! Thank you for the reply @Maximus-3 ...I ordered your winch mounting plate last week and received it a couple of days later. Look forward to an easy, trouble-free installation soon! Props for super fast shipping and a great looking product. The finish on the plate looks great and very sturdy.
jimmyzwheelz
Jimmy
Little Rock, AR
DenaliDan
Richmond, Indiana
2019 Granite Moab
Confirmed. I didn't have to make any modifications for the plate to fit. However, I'm unable to get to the driver's side inner bumper bolts with the Zeon 10s mounted on the plate. The diameter of the socket is too wide to fit between the winch and the chassis. I've been looking to purchase a slimmer socket but unable to find one. The space it's just barely too narrow. So close that it seems that if the winch did not have the raised logo on the end, it wouldn't be a problem. The passenger side was not a problem with the right combination of extensions. What specific socket do I (and others) have to use to get to the passenger side bolts?
SmartStopStart.com
Peak Sponsor (Level 2)
Arlington, VA
www.smartstopstart.com
2019 Wrangler JL Rubicon Unlimited Sting Gray
Electronics Engineer and Business Owner
Are you using a 12 point deep socket ? These are often a bit slimmer. Also make sure all four bolts that mount the winch to the plate are still pretty loose. I was able to get to both of mine this way, but it still was a VERY tight fit.
Stormin’ Moorman
Michael
Georgia
19 JLUR, 20 JLUR, 21 JL, 21 GCL, 89 YJ, 04 LJ
Forester
Don’t mind us, we’re just going to keep on answering your question for years to come. Heck, you’ll probably sell the Jeep and we’ll still be here voicing our opinions, needlessly. People will be flying around in jet cars...we’ll still be debating the best winch mount plate.
robaw
Rob
Iowa
A little late for you now but thought I would mention for others - the Warn winch plate comes with a "filler plate" that includes provisions for mounting your license plate under the fairlead at an angle. I personally added a flip-down mount (flipped up in this pic) but thought I'd let others know.
Jeep Wrangler JL Winch mounting plate EBCE3A98-DA78-4648-8941-13063123E49B
