- Max
- Oct 17, 2018
- Sterling Heights, MI
- 2020 Gladiator Rubicon, 2018 JLUR, 2015 JKU
Need to flat-tow your JL? Searching for ultra-strong closed loop recovery points?
If you said yes, then say hello to the Maximus-3 Tow Loops available for the Front and Rear of your JL.
KEY FEATURES
* Made with 5/8" High-Strength Low Alloy Steel
* Laser Cut
* Keyed-in and Welded
* Designed to act as a SKID, protecting your bumpers
* Dual powder-coat finish (zinc rich primer + top coat)
* Two color options: RED Gloss -or- BLACK Textured
* Lifetime Structural Warranty
* Made in America
Maximus-3 FRONT Tow Loops:
* Rated for flat towing
* Pair with Maximus-3 blue-ox tow bar adapter lugs part# JK1009TA
* Excellent for recovery operations - closed loop for safety
* Fits standard 3/4 d-ring shackle, with 7/8" pin.
* Designed for the OE Rubicon steel bumper (requires cutting the bumper and skid plate)
* Works with the factory plastic bumper (requires cutting the bumper and air dam)
* MAY work with aftermarket bumpers (cutting & modifications likely)
Maximus-3 REAR Tow Loops:
* Incredibly strong recovery points
* More recovery options with dual closed loops v.s. factory
* Designed for the OE Steel Rear Bumper (no cutting required)
* Works with the factory plastic rear bumper (requires cutting the bumper)
* MAY work with aftermarket rear bumpers (cutting & other modifications may be necessary
From getting out of a sticky situation to getting across country, the Maximus-3 JL Tow Loops have you covered.
KEY FEATURES
* Laser Cut
* Made in America
