Spring Rates
AnnDee4444
'18 JLR 2.0
This is an old thread but was going to try to comment on here instead of starting a new one.
Does anyone have any info that compares spring rates of the major players? I see RK comments above. Those are from a year ago but I would assume that still stands. Any info on some of the other main vendors?
I have the Mopar 2" springs now. I may be in the market for stiffer springs due to possibly towing a small camper.
Thanks.
I don't have the exact info you are looking for, but I can offer an alternative. The 3.0 Mopar lift springs should be stiffer than the 3.6 & 2.0
Jeep Wrangler JL Spring Rates Mopar Lift Springs
Jeepjunkie
Eric
Annapolis
2019 JLU Sport
Jeep Wrangler JL Spring Rates C195E403-9B22-411E-B0D4-FF4EB7D1A40C
Thanks.
RubiRob
Rob
Hampshire, IL
24 F-150 Raptor
Janitor
Thanks.
Front / Rear
JLU Sport : 117 / 172
JLU Rubi : 125 / 174
Mopar lift : 132 / 181
Synergy : 120 / 175
Teraflex : 140
RK 2.5 : 137 / 175
RK 3.5 : 140 / 185
EVO Soft : they wouldn't tell me
Metalcloak: they wouldn’t tell me
Halstem1
Alaska
Front / Rear
Synergy : 120 / 175
Teraflex : 140
RK 2.5 : 137 / 175
RK 3.5 : 140 / 185
Thanks! Evo wouldn't tell me either and I hadn't asked Metalcloak yet. This helps.
Kevin Mojito
Washington
2019 JLUR Moijto 2005 TJ AEV Hemi
We have posted it in a few other threads so here's a copy and paste from that, the first few lines refer to stock springs, then our springs:
“JLU Sport - 114/121 Front 171/174 Rear
JLU Rubicon - 123/128 Front 172/176 Rear
Mopar 2" Coils Lift - 131/133 Front 180/182 Rear
Our 2.5" Coil Spring Rates are as follows in the ride zone
137.5 Front at Ride Height
175 Rear at Ride Height
3.5" Coils are already coming in so we will give you those too
140 Front at Ride Height
185 Rear at Ride Height
The stock coils were dyno'd in house as well as at our spring supplier for confirmation of accuracy of rates."
Do you guys know what the 3.0 Diesel springs rates are ?
Herson
Herson
Michigan
2020 JL Wrangler unlimited rubicon
Have you dyno the 392 springs? If so, what is the rate? Thanks.
TxJeepers
2025 JLUR '41
Edit: added Teraflex rear rate based on the 3.5" springs
Front / Rear
Synergy : 120 / 175
Teraflex : 140 / 170
RK 2.5 : 137 / 175
RK 3.5 : 140 / 185
GavinH
Gavin
JLUR
Front / Rear
Synergy : 120 / 175
RK 2.5 : 137 / 175
RK 3.5 : 140 / 185
Just received my JKS 1.5 springs.
130 front 136 rear
Anyone know roughly the free length of jlur rear springs trying to see what these JKS are actually going to net me?
AnnDee4444
'18 JLR 2.0
130 front 136 rear
The range is pretty large. As an example, JL (2-door) rear springs have been measured between 14.125" - 17.5" free length.
Coil wraps, spring material, wire thickness, & vehicle weight also influence the final ride height... I doubt you'll ever get an accurate estimate off of calculations.
GavinH
Gavin
JLUR
Thank you I’m not sure why I’m sweating this small detail so much but I just can’t make up my mind if I should include my half inch teraflex spacer or just coils only. Plastic rear, stubby stamped steel front and 12k winch upfront. Spacer has me half inch lower in front rn so I feel I’ll need it with these new springs but with the rear only having 136 rating Idk how far that’ll drop. Front springs are 19 inches free length maybe a hair over like 19 1/8 and rear is 16 maybe a hair under like 15 13/16ths
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
Spring rates gathered over time. Not a complete list, and some of this may or may not have changed as years progressed. Data on Clayton and Synergy are listed on their pages so they are accurate. JKS data is from a recent enquiry I made with them as I was shopping for a 2.5" coil spring (fall-2023)
ManufacturerOption/VariantFront lb/inRear lb/in
JeepJLU Sport117172
JeepJLU Rubicon125174
JeepMopar 2" Lift132181
Teraflex2.5"/3.5"140170
Teraflex2.5"/3.5" HD170300
Clayton1.5"160137 / 200 (dual rate)
Clayton2.5"/3.5"188165 / 230 (dual rate)
Clayton2.5" HDN/A165 / 285 (dual rate)
Clayton3.5" HDN/A170 / 285 (dual rate)
Synergy1"95 / 120 (dual rate)115 / 150 (dual rate)
Synergy2"/3"110 / 120 (dual rate)140 / 175 (dual rate)
Synergy4"115 / 120 (dual rate)120 / 180 (dual rate)
Rock Krawler2.5"137175
Rock Krawler3.5"140185
JKS2.5"/3.5"110 / 175 (progressive)144 / 210 (progressive)
JKS2.5"/3.5" HD144 / 210 (progressive)152 / 210 (progressive)
OME2-2.5" Standard135160
OME2-2.5" Medium150 (bumper + Winch)175
OME2-2.5" Heavy---200
AnnDee4444
'18 JLR 2.0
interesting... I've read that the JKS 1.5" is 130 in the front... slightly higher than the 2.5"-3.5". I Really wish companies would stop trying to hide this info.
OminousSkitter
The Ether
Trek Bicycle
When we talk about spring rates, are we talking about the spring rate* (also called the spring constant) in Hooke's Law: F = -kx? Of course assuming non-dual/triple rate springs.
If so, would that mean that two springs of the same rate would compress (x in the above) the same amount to the same static load regardless of other factors like unsprung length or number of coils? Or is this a case where the real world application conflicts with the science definition (which happens a lot)?
