Spring Rates
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
www.instagram.com
2025 JLU Rubicon (Anvil Gray)
interesting... I've read that the JKS 1.5" is 130 in the front... slightly higher than the 2.5"-3.5". I Really wish companies would stop trying to hide this info.
Yeah I expected them to be higher too, the info I got is from their tech support team responding to an email I sent asking them for info on spring rates and shock valving.
I was leaning towards getting that kit, now I am not too sure.. I find the 160-front springs from Clayton plush and wont call it firm, so I might go with Clayton again when moving to 2.5 springs
AnnDee4444
'18 JLR 2.0
When we talk about spring rates, are we talking about the spring rate* (also called the spring constant) in Hooke's Law: F = -kx? Of course assuming non-dual/triple rate springs.
Correct. Rates given are how many pounds it takes to compress the spring 1" (lb./in.). Another common unit of measurement is kg/mm, but I've never seen Jeep springs with metric units.
If so, would that mean that two springs of the same rate would compress (x in the above) the same amount to the same static load regardless of other factors like unsprung length or number of coils?
Assuming the spring isn't binding or beyond it's free length, this is exactly correct.
While wire diameter/material & number of coils influence the spring rate, you can have two springs manufactured completely different from each other end up with the same rate... and they can be assumed to perform identically until their limits of their operation.
OminousSkitter
The Ether
Trek Bicycle
Thanks! I was thinking (and hoping) that to be the case. It lets me know the original lift I'm considering might not help fix the issue I'm having and I might need to find springs with a higher rate—either that or my rear springs are shot.
AnnDee4444
'18 JLR 2.0
I know some people will disagree, but I don't see anything wrong using spacers to level the front/back if you don't need/want a higher spring rate.
OminousSkitter
The Ether
Trek Bicycle
I have no problem with leveling it with spacers. Mind if I start a new thread with my current setup and problems (to keep this about spring rates) and tag you?
GrayWolf.Overland
Subash
www.instagram.com
Yep this is true. I started out with the Clayton 1.5 and my front currently sits with an additional 1" teraflex spacer to account for lift lost after a year of settling and steel bumper + winch
The ride quality is just the same as its still leveraging the same spring rate albeit sitting on top of a 1" puck.
GrayWolf.Overland
Subash
www.instagram.com
I circled back with them again and asked them to state both rates on their progressive coil. I update my table with the latest info from JKS. Sounds like JKS standard is plush riding and in the same ballpark as Synergy. JKS HD springs are very similar to Clayton's
JKS2.5"/3.5"110 / 175 (progressive)144 / 210 (progressive)
JKS2.5"/3.5" HD144 / 210 (progressive)152 / 210 (progressive)
AnnDee4444
'18 JLR 2.0
Interesting that the heavy duty only starts at +8 lb/in more in the rear, ending in the exact same rate as the standard springs... but the fronts heavy duty is very different.
GrayWolf.Overland
Subash
www.instagram.com
TIL Teraflex Front HD 3.5 springs are 170 lb/in linear
@AnnDee4444 - thats for the last row in your sheet. HD rates for teraflex are not filled in
Fast-n-Furious
PA
2022 392 XR
GrayWolf.Overland
Subash
www.instagram.com
Updates - Clayton HD Springs, Teraflex HD Springs
ManufacturerOption/VariantFront lb/inRear lb/in
JeepJLU Sport117172
JeepJLU Rubicon125174
JeepMopar 2" Lift132181
Teraflex2.5"/3.5"140170
Teraflex2.5"/3.5" HD170300
Clayton1.5"160137 / 200 (dual rate)
Clayton2.5"/3.5"188165 / 230 (dual rate)
Clayton2.5" HDN/A165 / 285 (dual rate)
Clayton3.5" HDN/A170 / 285 (dual rate)
Synergy1"95 / 120 (dual rate)115 / 150 (dual rate)
Synergy2"/3"110 / 120 (dual rate)140 / 175 (dual rate)
Synergy4"115 / 120 (dual rate)120 / 180 (dual rate)
Rock Krawler2.5"137175
Rock Krawler3.5"140185
OME2-2.5" Standard135160
OME2-2.5" Medium150 (bumper + Winch)175
OME2-2.5" Heavy170200
Seemego4WD
Tom
culpeper, va
2024 JLU xr
Anyone have spring rates for the aev 2.5 and 3 inch.
daverockville
Rockville, MD
2024 Jeep Wrangler Rubicon X - 3.6L
We have posted it in a few other threads so here's a copy and paste from that, the first few lines refer to stock springs, then our springs:
“JLU Sport - 114/121 Front 171/174 Rear
JLU Rubicon - 123/128 Front 172/176 Rear
Mopar 2" Coils Lift - 131/133 Front 180/182 Rear
Our 2.5" Coil Spring Rates are as follows in the ride zone
137.5 Front at Ride Height
175 Rear at Ride Height
3.5" Coils are already coming in so we will give you those too
140 Front at Ride Height
185 Rear at Ride Height
The stock coils were dyno'd in house as well as at our spring supplier for confirmation of accuracy of rates."
Nice work! I have a 2024 Jeep Wrangler Rubicon X (3.6L) with extreme recon (35s) from factory. Looking at upgrading due towing. Do you know what are the values for the front and back springs for my configuration?
