My new scissor jack setup
dapipp
NW Idaho
2006 TJ, 2006 LJ, 2019 JLR, 2024 JLUR
That is the first adaptor I tried with the HMMWV jack and it was just too wide for the jacking points on the front axle (see discussion about "AO adaptor" in my posts above).
Sorry, missed that or didn't remember that. Too many threads to keep up with some days.
flyer92
Nevada
OK...here's my last update on this unnecessarily long jack saga! Since the Safe Jack pad was a little loose on the ram, I found a 1" diameter copper sleeve at Lowe's, cut about 1/2" off of it and slid it right over the ram. Fits nice and snug on the ram, but a little looser inside the jack pad receiver, allowing it to swivel freely...not sloppily like it was before. Granted, I could have accomplished the same thing with a little duct tape, but the copper sleeve is more durable, less chintzy, and won't melt goopy sticky stuff when my jack sits inside a 200-degree vehicle.
flyer92
Nevada
Not sure this will help anyone, but it's possible to fit the 6-ton Torin Big Red in the cubby with the OEM scissor jack & all tools.
Just don't make this a daily storage location for the jack, as the hydraulic fluid will eventually seep out. Should be OK for a few days at a time if you're out overlanding/camping, but not good to store most bottle jacks like this for extended periods. There are several threads about this elsewhere in the forums, but just wanted to bring it to your attention. Enjoy and happy Jeepin'!
Cuyose
Shawn
Piedmont, SD
2020 Jeep Wrangler Rubicon
Data Analyst
In case the video doesn’t play. The pics show the 6 ton bottle jack in the cubby and the cubby cover secured in place without bulging or being pushed up by the jack.
What I want to know is how people can have a jeep that clean! Haha, I open that and I have to dig out a couple handfuls of rocks and mud :)
Jeff, what's the extended height of the HMMWV jack?
blnewt
New Mexico
Just ask @cosine he knows!
Traveling at the moment, but I'll measure it and get back to you shortly.
Yeah, that bottle jack really would be ideal for the space it takes up and the great amount of travel. Definitely interested as well :)
flyer92
Nevada
Just got home and quickly ran into the garage to measure. 18" at full extension with the adaptor.
Was that for the HMMWV scissor jack?
Yes sir...hope the info helps. What height do you need for your configuration?
My current rv scissor is a 7500 lb 24". I'll Probably stick with it.
blnewt
New Mexico
GrayWolf.Overland
Subash
Maple Ridge, BC, Canada
2025 JLU Rubicon (Anvil Gray)
I am not a fan of the OEM scissor, but am also not a fan of having hydraulic fluid leaking in my spaces. Is that really a good idea to store that bad boy on its side? I like the solution, just leery about leaks.
if fluid leak is a concern, Torin has one of these specific 6 ton models which is rated to be used horizontally
Torin - Big RED T90603C
https://www.amazon.com/gp/product/B0C82C37JL/
Jeep Wrangler JL My new scissor jack setup 1766007192135-rh
bd100
USA Midwest
JT
I will probably order up the following heavy-duty scissor jack from Agile Offroad:
https://agileoffroad.com/product/heavy-duty-scissor-jack-by-agile-offroad/
But I'll also have to order the Safe Jack axle adapter mentioned above for the tight space at the front axle, and add the sleeve as well. Too bad Agile Offroad didn't think of that.
The only thing is it looks like the shaft of the AO adapter may be too short for the SJ adapter.
