Had a jack stand collapse today.
mwilk012
2018 Ocean Blue JLU Rubicon
Service
I hate to rain on the parade, but that failed roll pin doesn’t appear to have caused the stand to collapse. Looks to me like all it does is release the lock after the weight is removed and you lift the handle. The ratchet was likely not fully engaged into a tooth.
Yea, that part failed but this is certainly not that big of a deal. I would say user error, but the OP clearly noticed the damage and nothing bad happened.
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
I agree.
I have a set of stands and the same thing happened to one of them about ten years ago. A simple roll pin replacement later and they have been back in service ever since.
Yawnie'sPapa
Central Iowa
I'm so paranoid that I use stands heavier than needed and if one will do, two are put in place.
I also have a habit of counting the notches and manually making sure the pawls are engaged fully. Then I stand up and shake the vehicle - a good hard shake. If possible, I even leave a jack in place.
I have 4 NAPA 6 ton stands, 2 Montgomery Wards stands from years ago (pin in hole, no pawl) and 2 from HF I use to hold up axles and such, or stabilize my trailer while loading a car (never use those to support a vehicle themselves) and two K made of heavy steel pipe and angle iron I used to hold up the front of a big Case tractor while I extended the frame and moved the front axle forward. They'll support a big diesel tractor even if they don't look like much.
My wife cringes every time I mention jacks or stands - she told me of a friend's husband years ago and it just sticks with you.
fat_head
2018 JLU
Because the pin is broken, theres no way to positively engage the teeth. The unlock bar is connected to the tooth that has that pin in it. I wish I knew the right words for all the parts so it makes more sense to explain.
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
I’m not sure the correct nomenclature either, but I’ve literally seen hundreds of those stands over my 40 year career. When they work correctly, gravity drops the pawl into a tooth on the adjustable part of the stand and holds it in position. Problem is the pawl doesn’t always set like it should for whatever reason.
I personally don’t use that type of stand because it’s hard to see if they’re actually locked in position securely. I prefer the old school pin type. You know that they’re set and secure when you put them under the vehicle.
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
CarbonSteel
I don't like the design of the "ratchet" style stands. It's difficult to see how much engagement the pawl is getting.
Look for stands that meet ASME PASE-2019 ASME PASE-2019: Portable Automotive Service Equipment - ANSI Blog
This is what I bought recently. 6 ton. They are truly heavy duty stands and the pin is about 5/8" diameter.
Floor Jacks and Equipment - Martins Industries
Martins Industries Heavy Duty Steel Lock Jack Stands (MJS-6T) (amazon.com)
I'm with you on the ratchet style and with the recalls that happened in HF and a couple of other brands (likely all the same maker) I like the ones you listed.
  • Like
Reactions: J0E
Jerpy
2021 JLU Rubicon
Carolina Jeeper
Rollie
North Carolina
2019 Mojito! Jeep Wrangler Unlimited Rubicon
Electronics Technician at R. J. Reynolds
Currently I have some Big Red 2 ton jack stands but they're really inadequate. I've been eyeballing the sunex jack stands. They will be overkill at 22 ton rating, but they are not going to fail. They rely on a large pin for height adjustment and have a flat base. Used them in the trucking industry to hold up semi trucks and trailers. Very reliable and very stable jack stands.
https://www.amazon.com/Sunex-1522-2...19011&s=automotive&sprefix=20,aps,102&sr=1-14
CaJLMetalHead
CAJLMetalHead
Jeep Wrangler Sport Unlimited
CaJLMetalHead
CAJLMetalHead
https://www.amazon.com/Sunex-1522-22-Ton-Jack-Stands/dp/B0093NBS9W/ref=mp_s_a_1_14?crid=1OMU8L1V9VNH&keywords=20+ton+jack+stands&qid=1676357695&refinements=p_36:1253497011&rnid=386419011&s=automotive&sprefix=20,aps,102&sr=1-14
++1
I've used them a couple times with the lifted jeep on 37s and my truck as well. Very much confidence inspiring, and the height range has been perfect under the axle tubes. I haven't jacked and supported under the frame with these, so I don't know if they're tall enough for the lifted JLUR in that use.
DaltonGang
Doesn't Play Well With Others
Go big, or go home.
