Best Ball Joints
Eischman
Kevin
Hortonville, WI
2021 Rubicon Unlimited
So, my 2021 JLUR Diesel has 17,000 miles on it running 35s, I'm planning on replacing the ball joints BEFORE it's a problem, sooo...
Metal Cloak Baller Joints, OR Dynatrac HD ProSteer ??
($$ is not an issue)
JINO
Jino
Socal
2021 jlurd
I don't know too much about ball joints, but many told me metalcloak baller ball joints are pretty good.
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
I went with the Dynatrac at 18K miles. Also, before they became a problem. I do appreciate the rebuildable feature. Don’t know if the MC are rebuildable?
Roky
Roky
I recommend Dynatracs based on personal experiences….. MC makes great products and I’m sure their ball joints are no exception, but I try to only recommend products I have personal experience with…
Dynatracs are rebuildable but the icing on the cake is they’re rebuildable in place. You don’t have to remove and replace to rebuild them….but you shouldn’t need to that often, which will reduce wear on the aluminum knuckles from removing and replacing….
Gregj
Greg
West Texas
Dynatracs are rebuildable but the icing on the cake is they’re rebuildable in place. You don’t have to remove and replace to rebuild them, this is especially important with oem aluminum knuckles, less you mess with aluminum the better the tolerances stay intact…….
I believe there is a slight error in your reasoning, the ball joints press into the steel inner C and the taper is seated in the aluminum knuckle and has to be removed to rebuild the ball joint. You are still removing and installing the knuckles.
Gregj
Roky
Roky
Gregj
Thanks, I edited my post, it’s been a long day..:facepalm:
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
Just fyi the MC Baller Joints are ā€œin Jeep rebuildableā€ as well. I have no experience with either brand, but at 43k miles on 37s I’m about to find out sooner than later šŸ˜‚
Roky
Roky
Yeah, I haven’t heard anything bad about the MCs, the only complaint I’ve heard so far is some shops scratching them up during install..
Camaroboi13
Justin
San Bernardino, CA
They’re very pretty that’s for sure. Isn’t that the reason we buy Jeep parts anyways? šŸ˜
Eischman
Eischman
Kevin
Hortonville, WI
The pretty red caps might be that extra $150 in price.
dlong1119
Gainesville, FL
21 Sahara 4xe (StingGray)
Dynatracs are on sale right now at Northridge (~$550), along with 20% off a lot of other stuff and you get a $150 gift card if you spend $1500 or more. A set of Reid knuckles, Dynatrac ball joints and a few other small items might currently be on their way to me right now! Total was $1500.19, couldn't have done better than that! Now I'll just have to decide what to spend the gift card and all the rewards points I've accrued on, lol.
