AnnDee4444
Interesting that the knuckle held up here... had it broken, it might have been a cheaper fix (but you wouldn't be driving home).I hit a raised berm of dirt going about 25-30mph with the passenger side of the rig. Had to swerve off trail to avoid a speeding biker coming over the crest in the opposite direction. Big long straight graded dirt road with some desert shrubbery and uneven terrain to the side - the uneven terrain is what my passenger side went out into. The front passenger wheel took the majority of the force, and the axle was the only thing damaged other than the wheel pushing up enough to pop a couple fender clips. I was running 29lb wheels and 66lb 35 Patagonia MTs and other than a Steersmarts track bar, the rest of the front end components were stock at the time.
The axle bent a few degrees upwards on that side - it didn't totally break but instead the FAD housing cracked at the spot welds and the tube going from the FAD to the C was pushed upward now that it was loose from the FAD housing's spot welds. Result was some funky camber on that side but was drivable (carefully) home. This pic was from below looking up, you can see the cracked paint between the FAD and tube suggesting upward tube movement, and if you look lose on the spot weld in the top right you can see cracks surrounding it. The other spot weld was a bit worse but I can't find the other pics.
Out of curiosity, what offset are your wheels/spacers? Was the sway bar connected during impact? Stock shocks?
