2.0 Engine Skid Plates
deserthi
Larry
2021 JLU Wrangler Rubicon Manual Trans
Any of you AZ people have the factory skid you can pass on to me? I just received my skid for the 3.6 and it utilizes the factory crossmember. I have a manual transmission which does not come with one. Ugh. Help?
I am in the desert of Calif and just got a 2021 JLU rubicon with manual. I noticed that that cross brace. I had to order if from MOPAR. Should be here this week.
AZ Hella
Sonoran Desert
JLUR
My 2021 manual rubicon did come with one.
gato
New England
2021 JLUR
The oil change is a pain with the Asfir and I’m working on a solution that would be best implemented BEFORE you install. I picked up some JB Weld Water Weld (for use with aluminum). It’s basically a dam.
I kneaded it and made it into a rope (it’s a touch more gooey than the regular JB from my memory. Just wait for it to start to get warm from the chemical hardening process and that should make it easier to work with. Get the section of rope into position and press down/contour as you see fit. I put a curve in one side to cup the area.
I did the drain plug area and forgot about the mess the oil filter adapter drains down until the oil change so now I need to go back in and add more. SMH
Again, get some Water Weld and do it before you install. It’s more difficult to do a nice job because it’s tight above the skid.
Borowing a pic looking from the front of the skid from MILT earlier in the thread to illustrate (Thanks)….
To get the drips to break off and fall on both sides of the cutout rather than running down toward the back of the Jeep I’d run the rope of weld over the edge of the cutout and actually come to a small piece pointing down past the bottom of the skid.
Hi do you have the 2.0?
I have the Artec aluminum skid, and I had the dealer do the "free" oil change an my transmission/tcase skid was dripping oil for 2 weeks since it was pooled there. I'm trying to find out if the oil just sprayed past the hole for the drain of from the filter or what.
Do you have any more pictures of the bath the oil was taking? and the dam?
Thanks.
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
Thanks.
Yes, a 2.0 and it runs from the filter and when the drain plug is just barely making a stream or dripping…it runs the general downhill path of these blue lines pictured and comes out of both rectangular holes at the back.
I have part of it Pictured in my last post on the edge of the picture. Problem is I need to modify the dam (grinder) and make a couplemore coming from the oil filter area funneling it all to the drain plug cutout area.
Jeep Wrangler JL 2.0 Engine Skid Plates F3BA837B-3083-42FD-AF27-957282871ACC
AZ Hella
Sonoran Desert
JLUR
gato
New England
2021 JLUR
Thank you for the detailed answer. I'm a masochist. I keep on taking the Jeep for the "free" oil change and tire rotation, only to find my lugnuts severely overtorqued, my belly skid full of oil and having to waste time removing/reinstalling the Tazer.
Why do I do these things? It's right up there with taking the free breakfast/beach day at a timeshare pitch only to be held hostage for 2 hours afterwards.
gato
New England
2021 JLUR
AnnDee4444
'18 JLR 2.0
Asfir vs. M.O.R.E.
The M.O.R.E. is wider, but unfortunately doesn't fit 2018 2-doors due to the gas tank (2019+ is OK). Even thought the M.O.R.E. skid was way heavier, the Asfir brackets were actually heavier.
Asfir skid ≈ 4 gauge aluminum
M.O.R.E. skid ≈ 8 gauge Steel
Asfir brackets ≈ 0 gauge steel
M.O.R.E. brackets ≈ 3 gauge steel
Jeep Wrangler JL 2.0 Engine Skid Plates PXL_20210918_150415636
Jeep Wrangler JL 2.0 Engine Skid Plates PXL_20210918_150739713
Jeep Wrangler JL 2.0 Engine Skid Plates PXL_20210918_150642234
Jeep Wrangler JL 2.0 Engine Skid Plates PXL_20210918_151406795
Jeep Wrangler JL 2.0 Engine Skid Plates PXL_20210918_151435537
Jeep Wrangler JL 2.0 Engine Skid Plates PXL_20210918_151053409
Jeep Wrangler JL 2.0 Engine Skid Plates PXL_20210918_151517256
Jeep Wrangler JL 2.0 Engine Skid Plates PXL_20210918_151537182
AnnDee4444
'18 JLR 2.0
M.O.R.E. skid ≈ 8 gauge steel
Forgot to add the stock crossmember for comparison: 14 gauge steel "tube"
Jeep Wrangler JL 2.0 Engine Skid Plates PXL_20210918_151455476
  • Like
Reactions: J0E
MarkyMark
San Francisco, CA
19 Rubicon JLU 2.0t w/ eTorque & Moto Guzzi Griso
  • Like
Reactions: J0E
cs2k
Clarence
San Diego, CA
2021 JLUR 2.0
Engineer
entropy
Foothills of the San Gabriels
OF top 1% content creator
Valvomax oil drain system. I installed it on my last oil change right before installing the Asfir skid. It comes with a little drain tube you plug on their drain bolt, so oil flows through a tube and you can direct it wherever you want. It was cheap too, like $40 maybe?
Havent tried it yet but hope it works!
Odyssey USA
Daniel
www.youtube.com
2021 JLU Rubicon
Someone has suggested this a few times. If I smash my skid, I’ll definitely smash a valve hanging out. And it’ll give leverage to harm the threads is my thinking.
entropy
I dont think it sticks out enough to be smashed. Plus if you end up bending the skid that badly itd have to be a catastrophic hit, and youll smash other things including the oil pan. There is also a big hole on the skid where the valvemax is located. I honestly dont think this is likely. But I dont know how close to the skid it is on the 2.0. It is pretty far on the 3.6. I also hope the skid has enough support to not go that far on a hit. Hell if it does it would cause more damage than that lol.
