2021 2.0 Engine Whine
Kombine
Kevin
19 JLU Sport
Bought a new 2021 Rubicon with the 2.0 Turbo (without E-torgue). Mine makes a loud whine when accelerating starting at around 1500 RPM. The engine noise does eventually get louder but its still there. I've watched exhaust videos and can here it in there and I've just assumed its normal but I cant find anywhere with definite information as to what the noise is.
Jeep is completely Stock.
Dont bash me to hard I'm also aware I'm hyper sensitive to engine noise.
Only reason I'm making this post is I finally did lite off-roading and in 4lo the noise is much louder.
Just want technical information as to what the noise is.
Video of my jeep making the noise. the video is also reference for noise in case anyone else has the same concern. I know there are posts about it but none with video of the noise.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
LOL, sounds exactly like mine.
It's like a police or fire siren when it varies its pitch like that.
Few times I almost pulled over trying to let the police/fire truck pass but found none.
Eric
Madisonville, TN
‘20 JLUR
Wow! Is it that loud in the cabin? Mine is not that loud even though it is noticeable with the windows down. My wife asked about it once, but really ours doesn’t appear to be that loud. Be interested in what others think for sure.
Chupacabra
Littleton, CO
2021 JLU
I can barely hear what is probably a slight turbo whine with the windows down on mine, can't say I've noticed it in the winter with the windows up and heater on though.
Never heard it make a noise anything like that video though, that almost sounds like something is rubbing or grinding?
Arterius2
Jerry
Vancouver, BC
I have an aFe 'cone' style filter in mine. So probably more airflow than stock.
It's far more noticeable when driving at night though.
Cypher
J
AZ
2020 Jeep Wrangler Unlimited Rubicon
Cybersecurity Leader
there are others reporting similar with the Eco-Diesel as well. it sounds almost like the Turbo bearings.
Kombine
Kombine
Kevin
19 JLU Sport
  • Thread starter
  • Thread Starter
  • #7
It should prolly be noted that I had it floored coming up the hill in 1st gear in 4l0 which is prolly why it sounds so loud. Video was takin on a phone as well which might make it sound worse. Just took it to a dealership and the foreman says its nothing he would be concerned about because of all the electronics on these new turbos that its prolly an actuator opening up slightly.
I've noticed in some videos that the Alfa Romeo Gulia and stelvio 2.0 also make this noise.
Kombine
Kombine
Kevin
19 JLU Sport
  • Thread starter
  • Thread Starter
  • #8
No It doesn't not sound that loud in the cabin with the windows up. This is completely stock airbox too. I'm sure aftermarket intake and exhaust with bigger tires will start to drown it out a bit.
BigGreen
Al
Arizona
JL Sport
Could be the balance shaft. Mine sounds like that too. It reminds me of the police motorcycles.
If you are sensitive to engine noise, this 2.0t is going to drive you nuts.
Engine Guy
Chip
Atlanta, GA
2019 JLUR
Engineer
Yup, my 2019 sounds pretty much just like that.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
Sounds like turbo whine combined with the diverter valve dumping excess boost into the intake. The high rpms are making boost, but low gearing and momentum are minimizing the actual load on the motor, which would cause boost to be dumped into the intake. I wouldn't be concerned.
So, did you have fun? Looked fun.
bigfoot21075
Robert
Maryland
2021 JLUR, 2012 Ford F350
That is a normal turbo charger sound making boost.
Boogey
Rami
Virginia
JLU Sport S 2021
I got the JLUS with the 2.0T and it rattles like a diesel but absolutely no whine at ALL, and i mean at all.
If no one told me and i watched this video, i would assume something is surely not the way it should be , too loud in my opinion
bigfoot21075
Robert
Maryland
If no one told me and i watched this video, I would assume something is surely not the way it should be , too loud in my opinion
Rattles like a diesel when cold ESPECIALLY!!!! It can be a tad startling when you first hear it in the garage! 🤣
That one in the video is fine there nothing wrong with the way it sounds.
Boogey
Rami
Virginia
JLU Sport S 2021
Yes on a cold start it feels like the engine is about to fall apart but just smooths out instantly when warm.
The whine though....I have none of that, i do hear a slight slight whine when i floor it going 40 or so but not a constant one at slow speeds like that.
by the way do all JLs have a small steering high pitched , low whine/squeal when turning standing still? I hear it alot at the mcdonalds drive thru :)
Tazer JL - Z Automotive
