AdamG
- Adam
- Feb 17, 2021
- SE Michigan
- 2019 JLSportS - SOLD; 2026 Moab 392
Completely understand that the Rubicon fenders allow you to run bigger tires for the same amount of lift. My question is if you take a lift and put it on both a Sport and Rubicon specced the same way (same bumpers, same tires, same top, etc), will their door handles end up at the same height? I think the answer is yes, and the reason people get different results is they start with something that is not the baseline that the lift manufacturer started with - putting a lift on a plastic bumper soft top 2.0 model will result in it being higher than a steel bumper hard top tow package 3.6 model simply due to weight differencesYou need to lift a sport higher then a Rubicon to clear fenders. Again, Mopar themselves do not market their lifts by model they market them by engine size. Each engine has a different weight rating.
aftermarket companies will market differently as they go by what size tire you want to run with your lift. Like I said Rubicons have highline fenders which allow them to run larger tires with less lift.
