Krazyk86cu
So, if I want to just use the ARB switch on the ignition wire under the glove box, any idea which lead I connect itYeah, pretty much what Cram501 said. The compressor actually has it's own built in relay. The purple wire just turns it on. That being said, pretty much any 12V+ source will work to activate it. Amperage really doesn't matter in this case. I had originally planned to use an Aux switch when I started doing the wiring for mine, but then my install lent itself to using the ARB switch. So, my ARB switch ended up hooked up to an Aux switch. Pain in the butt to have to turn on both switches, and its really a waste of an Aux switch for me. I'll be wiring my ARB switch to the ignition switched lead next time I have the kick panel off.
Right now I have the ARB twin on aux4. I’ve decided to use the ARB switch instead of my aux switch. I don’t care about the dimming function, but can I split the under dash ignition wire into 2 and to light up and power the switch? And obviously ground the switch as well.If I were to re-do the wiring I would:
1) Use the ignition power wire in the passenger foot well, versus one of the AUX.
2) Would use the ARB switch to turn on/off.
Right now I can reach the aux no problem as compressor is under a seat but a waste of an aux.
. I'm guessing you used two single 24V compressors (CKMA24 = 18A max. ea.)?
