Intake box modification
Rockmaninoff
Melbourne, Australia
sophistijeep.blogspot.com
MY2014 JKU Overland (RHD) A/T, Mercedes E-class MY2017
Can’t speak to the 3.6 Pentastar but I added a long tube air inlet and a K&N cone filter on my FX35 and it had a significant impact on the exhaust sound. Made it more throaty and loud.
That's called induction noise and you hear it when the engine is under load. Exhaust and its noise comes from your tailpipe. In a Wrangler, changing the air intake has no connection to exhaust noise because the muffler is very quiet. Even a positive displacenent supercharger which seals up the intake behind rotors that act like revolving doors and force feed more air doesn't make the stock exhaust any louder or different.
In your other vehicle, the cone filter and the length of the inlet tube had very little to do with the throaty sound. Stock air intakrs (and even some aftermarket ones) have Helmholtz style resonators that smoothen out the pulses and therefore the noise. The inlet tube material might make a tiny difference depending on its sound absorption properties. E.g. metal one would make it sound a bit tinny and a plastic one makes it absorb some the high frequency noises and therefore makes it sound less tinny. The presence/absence of an airbox also makes a bit
Long Island
2018 JLU
I plan on putting a K&N filter in as soon as they are available. I tossed around the idea of a cold air intake but the Mrs., who's Jeep it is, doesn't want a real loud growl.
So I thought what would happen if I opened up the bottom of the intake box? It would allow more air in than the standard box, but not as much as a cold air intake and it will be slightly louder than standard but not as loud as cold air.
Is this a dumb idea?
so you want to open the sealed air box of a wrangler ? why did you even buy a jeep smh
Rockmaninoff
He can donk his jeep and slam it and add some serious camber if he likes.
You needn't worry about what anyone does to their jeep just like you needn't worry about what goes on in their bed room unless your husband/wife/spouse/a child/dependent is in there too.
Spank
This is true. Except for the part where he created a thread and literally asked everyone
to which the general consensus is yes.
Why? What exactly are you trying to accomplish with a CAI on your Wrangler?
JPWILLY
Erik
Wisconsin
20 JLWilly 21 80th
So I’m here to stir the pot on this old thread. I have a 2020 Willys 3.6 and have a CAI(of sorts) with a K&N drop in filter in the original housing and air system. I bought the “Short Snorkel” set up and it pulls air from the passenger side fender (near the windshield). It gives a throaty growl but not very loudly, it is all because it still has the factory air box and piping to the throttle. If I were to swap out just the piping to a more straight (and without the resignator) then I’d hear the intake much louder.
Jeep Wrangler JL Intake box modification CE37055A-96C9-4E3A-9992-EF2CB39D1B20
mgroeger
mgroeger
Southern UT
2021 JLUR 2.0T
Can you show some pics from under the hood?
DHW
Atlanta
2018 Rubicon
Attorney
I've heard from other 2.0T owners that adding a CAI to this engine significantly increases the turbo noises. That would be cool, but I'm sure as hell not messing around with this Rube Goldberg of an engine. Its complicated ass is staying under warranty.
Edit: Damn, didn't realize the majority of this thread was from the JK era.
RedundanT
So. Il
2020 JLUR
Soooooo.... is there a reason folks like a gauze filter that lets in LOADS of finite BS into their engine? Or am I just an arsehole for thinking that a nice paper filter that removes all the microparticles of garbage from their engine is a good thing.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Jesus guys, learn from an old fart that did this 20 years ago. Don’t cut your air box on anything, much less something you plan on fording a stream with.
CAIs can help turbo motors WITH the right tune, but keeping water out is much more important.
I’m down with souping up the 2.0T, but you want a JB4 and cat less DPs. Don’t try to out BOV a Civic (which this wouldn’t do anyways.
