How Important is Torque for Off-Roading
Humvee4us
Jeep Wrangler Rubicon 2 Door
I have another post in this forum comparing and contrasting the Jeep Wrangler Rubicon with a few off-road pickups. As such, I got curious and begun calculating the total amount of force that each wheel can get as this should be a very good measure of how capable a vehicle is off-road. For example, if it's very muddy the more force the better, right? Or in the snow, or a steep increase, or to climb a rock. The larger the force, the easier it becomes. So I did some calculations and something like a Ford F 350 Tremor, even with a significantly lower crawl ratio and taking into account the much heavier weight, each wheel on the Tremor should have significantly more torque due to the fact that the Tremor's engine produces so much torque. So does this mean that physical size of the truck excluded, the Tremor should get stuck much less often than the Jeep Wrangler and also be able to climb steeper hills?
txj2go
DFW
Not sure what you're getting at?
Where there are discussions of "torque" the benefit is if the engine has more torque at lower speed, that way you don't have to rev the engine as much or change gears as much to move, it makes it more flexible to drive. Horsepower is really what makes the vehicles move, despite the arguments that better torque (meaning better low end torque) makes the vehicle faster. A wider power band will help but some engines with good low end torque run out of horsepower quickly at higher rpms. 2 engines with equal horsepower will pull the vehicle the same if each is geared to take advantage of its horsepower. However you wouldn't want a Honda S2000 engine in your Rubicon because you would have to run it at much higher rpm.
With sufficient low range gearing you get all the torque multiplication you want. I've seen Wranglers and WK2s in low range on steep rock spin all 4 tires at the same time. It is hard to use more torque than that, at least for rock crawling.
aldo98229
Aldo
Bellingham, WA
Market Research
^^^ this!
Without traction, torque is useless.
Humvee4us
So then for off-roading adding a bigger engine with more torque, such as the new diesel engine available only for the 4 door Wranglers, that's not going to help me at all when off-roading? I already have all the torque that I could need, the tires would lose traction before my engine runs out of torque?
Joe98
Sydney
2019, 2 door Sport S, Mojito!
You are pushing the right front tyre over a big lump. If you have little torque, than as you get to the top of the lump, the tyre has less resistance and the vehicle will take off like a rocket!
With lots of torque, then after reaching the top, you can gently lower it down the other side.
INCRHULK
Lance
Canada
litwphoto.com
2019 Wrangler Unlimited Sahara (retired), 2021 Gladiator Rubicon Diesel
Program Manager, Information Technology
Part of the advantage a diesel has is its low end torque. You want torque as low into the power band as you can get it for control.
Amaruq
Atlanta
JLR 6spd
Just out of curiousity, because you seem really passionate about the joy of off-roading (which is awesome): how much experience do you have driving off-road? Rock crawling?
scrape
ca
Fiat
Engine torque is only important if you have a manual transmission and not enough gearing. Then it can help you crawl without stalling all the time or having to slip the clutch.
With an automatic OR if you have deep enough gearing with a manual, then it doesn't matter.
Dude the rubicon has something like an 80:1 reduction in 1st gear 4low. Let's say the 3.6 v6 makes 50 ft/lbs of torque at 1000rpm. After an 80:1 reduction that is 4000 ft/lbs of torque at the wheels, before drivetrain losses. You need more than that?
txj2go
DFW
They're both numbers, torque is a twisting force, horsepower is a measure of power, it's torque times speed.
Engine torque is only important if you have a manual transmission and not enough gearing. Then it can help you crawl without stalling all the time or having to slip the clutch. With an automatic OR if you have deep enough gearing with a manual, then it doesn't matter.
Having a wider torque band, or torque at lower rpm just means you can run the engine at lower rpm so it doesn't sound like you are killing it, and with manual transmission it is more flexible because you don't have to shift as often.
INCRHULK
Lance
Canada
litwphoto.com
Hate to break it to you, but torque is a number as well.
Karnak
Yan
Ottawa, Canada
19 JL 3.6 Sport S - 2 door
government
Pickups compared to jeeps.....Weight distribution my friend....apples to oranges...can't compare...totally different vehicles and behaviors on any surfaces. I know, cause I have a pre-runner Mazda on 35's and used to have a TJ on 33's...can't compare...at all...sorry.
what your trying to compare is like trying to compare a motorcycle acceleration on quarter mile based on torque to the acceleration of a car on the same track. I see comparisons like these all the times made by Trolls on forums to see people's reactions....;)
