DEF Usage
GearWhore
2021 JLUR Diesel, 1972 Arctic Cat Climber
Gentleman Explorer
I just filled my '21 Rubi 's DEF tank this afternoon for the second time since delivery. Currently at 6500 miles. First DEF fill was at 3000 miles (full at delivery). 8.753 gallons total; 745 miles per gallon. Pretty much at the 3% fuel consumption mentioned previously. I too feel misled by Jeep that refills would only be required every 10k with oil changes. My '18 WK2 ecodiesel would go 10k between, but with a 30% larger DEF tank. Still had a much lower consumption rate than the JL.
Gorilla57
Chandler AZ
2019 JLUR Mojito
Nice to see someone actually calculate out their DEF use. Too many people complain and yet have NO idea what their use is.
Yankee1019
Charleston, SC
2012 RAM 1500 Crew Cab, 2023 JLU Reign Willys
I was doing some research into how to decode the batch/date codes that some DEF manufacturers use for their products in relation to another thread and came across this.
How much DEF will I need?
Your DEF consumption will be approximately 2-6% of your diesel fuel consumption (approx 2-6 gallons for every 100 gallons of diesel used.) The newer model trucks will consume more DEF but offer better fuel mileage.
https://colonial-chemical.com/diesel-exhaust-fluid/#diesel-exhaust-fluid
They're my DEF supplier so maybe I can convince them to give me a decoder ring.
GearWhore
Gentleman Explorer
That would seem to track with my experience too, then. Though my Jeep went into the dealership last week at 6600 miles with an oil leak on the driver's side of the block.
Yankee1019
Charleston, SC
I heard back from my supplier today re: the date codes. The DEF I use is in 2.5 gallon jugs (we purchase directly from the manufacturer) and have the codes stamped on the jugs (example: TAB20-DE0603). TAB is the manufacture location, 20 is the 2-digit year, they didn’t elaborate on what the DE signifies, and the 0603 is mmdd so June 3rd. I don’t know if there is any relevance for other OEMs so it is what it is.
rickinAZ
Phoenix
2026 MOAB 392
Why can’t it be as easy as a quart of milk? Seems like they’re turning a routine pop fly into a circus catch.
FinnCustomKnives
Woodstock, GA
2021 Wrangler Rubicon Ecodiesel
We burned through the 3/4 tank of def that the jeep had from new. Granted today I towed this giant parachute 450 miles through the winds this cold front is bringing in. Went through nearly 3 full tanks of fuel ?. Only tow this with the top on, on slow roads. However I ended up winning both auctions that I bid on recently on govplanet. Which meant the trailer had to go on the interstate as is?
Jeep Wrangler JL DEF Usage 20210421_200453
Jeep Wrangler JL DEF Usage 20210403_141840-01
BuffaloBill
WI
2024 Wrangler 2.0, 2020 wrangler 3.0
Nice trailer by the way. Looks great behind your Jeep. Wow, does it have tongue height!
BCFRJeeper
Panama City Beach, FL
1991 Wrangler YJ 2020 Wrangler Sahara Unlimited
Retired Navy
I have driven mine a little over 3,000 miles and mine has moved less than a 1/4". Still hanging out at just under half a tank of DEF.
FinnCustomKnives
Woodstock, GA
Thanks!
Yeah the M1102 is meant to hook up to a HMMWV, so the lunette ring is at 29.5" off the ground, when level. Leaving it be and using the riser hitch for this first trip to Moab and Ouray in July. However afterwards I am going to convert the hydraulic surge brakes to electric while installing a 3500lb axle, lower the mount/couple and switch to either a max coupler or cruisemaster Do35 coupling. Granted once we finally lift and go 37's it may be just about perfect height as it sits.
Unfortunately the hitch has so much rise that the spare won't fit on at the same time
Horsemover
Jamie
NW PA
2021 JLURD / 1997 TJ 4.0
I refilled mine last night for the first time at around 3,700 miles. I was 300ish miles from a restart. 2.5 gallons filled it up to 3/4 of a tank. I was thinking maybe it wasn't topped off on the first fill but after reading some on here my use seems somewhat typical.
TheMike
Anchorage, AK
Red 2021 JLURD "The Big D"
Supervisor, Air Traffic Control. RETIRED at 51 baby!!!
I've had my Jeep for almost 2 months. I've put over 7100 miles on it and have put in 7 gallons of DEF. I've towed for most of that so I kind of expected it.
Bought the vehicle and drove it to Vegas. 27 mpg
Towed about 2000 lbs from Vegas to Denver. 19 mpg
Built up the Jeep did some other things (to include 37's). Drove around for 4 weeks without a trailer. 22 mpg
Then towed about 2500 lbs from Denver to my home in Anchorage. 18.4 mpg (put the factory 33's back on for this trip).
So if I consider 1 gallon of Def fluid per thousand miles normal, then it's good. Those written earlier that they go 10k miles between fills of their DEF with a 10 gal tank.....then I'm right on par.
rickinAZ
Phoenix
2026 MOAB 392
I have the opposite problem: I accidently ordered a 4-pack of 2.5 gallon jugs (damn that one touch buy button on Amazon). I only drive about 6,000 miles/per year, so now I'm virtually willing the DEF level to drop so my "inventory" doesn't go stale.
  • Haha
Reactions: GtX
No Spark V6
Chicago NW burbs
2021 Rubi 3.0 GCM
Guess you gotta drive the jeep a bunch now. Sounds like a good problem to have!
