DEF Usage
Capricorn
Las Vegas, NV
2024 JL Willys XR V6
Network Architect & Engineer
Is all DEF the same? Or do we need to go to dealer to get what our Jeep needs?
This is my first diesel......
According to the manual, any DEF that is API certified to ISO 22241 standard.
HappyJeeper
Eric
San Bernardino Nat'l Forest. Calif.
'20 JLURD, '09 Tundra 5.7 4x4, '21 Prius
Soils engineering/geology
Cool. I know it has a shelf life. I don't put a lot of miles on mine, so I need to keep an eye out for that.
A.DiVe1
Andy
In my Wrangler in Illinois
2021 JLUR Diesel
Compression-Ignition
Roy
Montana
'22 JLUR 3.0 Diesel, '20 6.7L F350, '94 12 valve
Roy
Montana
Interesting. I just buy the name brand stuff (PEAK). Next time I go to buy some I'll look at the off brand stuff and see if it has an API cert label on it.
Seems odd that as nuts as they are with all this emmisions garbage, they would allow sub-grade DEF to be sold.
I still wonder if I'll be able to find any non-API DEF in my area, but I guess I stand corrected.
WXman
Central Kentucky
I have never seen DEF that wasn't labeled as certified. I'd be willing to bet that the $7 Walmart brand comes off the same line as the $13 PEAK brand. Y'all are overthinking this. It's a urea/water mix. Not a lot to go wrong there.
Oldbear
Dwayne
Bowling Green, Ky
16 Ram 1500 Ecodiesel; 20 JL Sport S 2 door
Also note that short runs = more regens= more DEF useage. Also suggest that you just fill up with DEF at the pump at any decent sized truck stop. Much cheaper and you will know it’s actually full. in my Ram the tank is like 8 gallons, and that’ll go pretty much 10k or more.
Oilburner
You'll never find me
Jeeps
(Painful as it is) I have to agree with WXdude here- :giggle:
Also: my 2020 JL diesel seems like it is using less DEF than when we first got it, perhaps part of the system learning your driving habits? I think it still uses more than advertised now, but I am usually pulling a trailer.
WXman
Central Kentucky
I believe that idling increases usage, and cold weather does as well. That may be why most of us saw decreasing DEF usage as we got into summer. When I got mine it was February and the DEF needle dropped fast. Now, not so much.
Parratt
Logan
Edmonton Alberta
2020 JLUD, 1988 MJ, 2010 XK (Sold)
Went through half a tank of a def in about 2500Km i Think thats a bit wild eh.
Capricorn
Las Vegas, NV
About normal.
Real life normal that is.
AZ-Chris
Arizona
2020 JL Unlimited Rubicon Diesel
I've got 5,700 miles on my Rubicon and I've already added 5 gallons of DEF since taking delivery and my tank was topped off when I took delivery.
Capricorn
Las Vegas, NV
I checked the gauge when I was at the dealer taking delivery. It wasn't full, so I had them top it up. Went 7000km showing half full.
That's about 4300 miles. That's pretty good. Mine was showing full on the gauge but went down to 35% after 3500 miles. And 90% of my miles were highway miles and each trip averaging 15-20 miles commute to work.
