Backup Lights
CarbonSteel
I am about to start this project myself (waiting for my Borla S to arrive this week so I mount the lights in the best place) and I want to keep my diodes under the hood.
To that end, has anyone tapped into the trailer backup wiring under the hood? I looked at the wiring diagrams and the wire appears to go up to a relay somewhere under the hood.
Anyone have any insight?
SeanD
Sean
Oregon
2018 Jeep JLU Rubicon, 2013 Acura RDX
I really liked @Jeeper ‘s idea using the Rigid Scene Light, but chose to mount it to the side of my hitch like many others using a single light (eg, Baja Designs S2) rather than to the bottom of the hitch where it would have been more nicely centered. I was worried about it hanging down too far and being exposed more than I liked.
The Rigid Scene Light is relatively inexpensive ($82 on Amazon) and has a sleek, low profile which is quite elegant. However, because it doesn’t project the light out straight, it won’t be as bright and evenly spread as some other dual light solutions (which will surely bug my OCD!), but it is still quite an improvement and adequate for my needs.
I just wired it direct to Aux 4 for now going through the frame rail, but will eventually also wire to the backup lights behind the passenger side taillight using the two diode approach. I just ran out of time today.
And yes, I still need to paint my muffler. ;)
Jeep Wrangler JL Backup Lights 44230CA5-193A-439F-868C-8F5E19CA6C26
Jeep Wrangler JL Backup Lights A9E5970C-E0D9-495E-A75B-7794DF7AEEDC
Scarr2k
NC
19 JLUR
Here is what I did. Looks factory to me. Super bright! No low hanging issues as with other lights. 1260 lumens each!
@ColoradoRubicon - Love the light install and actually ordered a set based on this. One thing I wanted to ask has anyone installed this exact set of LED's from e-trailer on a plastic bumper with the backup sensors? I believe I have two sensors right where @ColoradoRubicon installed his. I've seen a few Rigid flush mount LEDs that were mounted on the outer edges of the bumper with backup sensors but wanted to see anyone who used the e-trailer ones.
spurly
Zach
Nebraska
2019 Bright White JLUR
Well I read through the entire thread sitting at the bar tonight. Ok more like skimmed.
I have a new aftermarket bumper arriving tomorrow that I will be installing 2 Baja Designs S2 Sport flush mounts into. I've been planning on wiring them up to both the AUX switch AND and the reverse lights. I will not be splicing into the taillight wire harness for the reverse switch power but instead splicing into the reverse wire from the 7pin trailer harness to switch the relay AND the charge wire from the 7 pin harness to provide 12v power to the lights. After reading through the thread, I think I may have (but now I'm second guessing myself) simplified the wiring a bit but I wanted someone to double check my math so to speak (cough @Rhinebeck01 cough). Roadmaster actually makes a 2 in 1 out diode that should make this a bit easier.
(The 5 amp fuse off the charge wire is just extra security and the "switch" I show coming off the 7pin reverse lights is just my way of saying this is the trigger for the relay)
On paper it works, but will the Jeep like it?
Jeep Wrangler JL Backup Lights 20190909_202905
spurly
Zach
Nebraska
Well I guess Rhinebeck is no longer on the forum according to his profile. So maybe someone else can help check my math.
SmartStopStart.com
Peak Sponsor (Level 2)
Arlington, VA
www.smartstopstart.com
2019 Wrangler JL Rubicon Unlimited Sting Gray
Electronics Engineer and Business Owner
Mostly this is OK, but It is unnecessarily complicated. You do not need to add a relay since the trailer harness backup light already has a dedicated built in relay in the vehicle for for the trailer lights. The only other issue is you have drawn the ground to the two lights on top of the power wires to the lights. The ground to the lights is a separate wire.
spurly
Zach
Nebraska
Good point, I was planning on using the wire harness that came with the lights because I didn't think about the 7pin reverse already having a dedicated relay. The ground for the lights was a last second catch and I ran out of room on my tablet to correctly draw it in. This should be much easier.
Jeep Wrangler JL Backup Lights Screenshot_20190910-190445_Samsung Notes
CarbonSteel
I joined the backup light club yesterday and it took about 4 hours (really took my time to do everything right). I connected the lights to Aux #4 and to the backup light lead for the 7 pin trailer connector. I could not justify the cost of the Rigid branded lights (for something that may be torn off) so I used two ADZOON 2'' 27W Waterproof Mini LED Cube lights.
I ran marine 14/2 wiring inside 3/8” split loom tubing from the engine bay to the rear using a ¼” 25 foot fish tape (https://www.lowes.com/pd/Southwire-25-ft-Steel-Fish-Tape/50114239). This particular tape is great and when I initially ran it through the frame, it hit an obstacle very quickly. I thought -great, this is what everyone has struggled with, but when I began tracing it, I was pleasantly surprised to find it hitting the bumper—totally painless, but I think the ¼” blade versus the more common 1/8” blade made the difference.
All wiring was ran inside split loom tubing and taped at appropriate intervals. All connections were either covered in heat shrink tubing or siliconed and taped. The crimper I bought does a much better job than my Thomas & Betts crimpers (https://www.amazon.com/Thomas-Betts-WT111M-Insulated-Terminals/dp/B0018LD2PU) which have a tendency to cut through the insulation.
I installed a diode in the engine bay for the wiring running from Aux #4 to the rear and installed a second diode at the top of the rear passenger taillight cavity. All in all, I am very pleased with the results and the increased light at night. Jeep seriously needs to do something about the OEM LED backup lights—they suck to the point of being dangerous.
Major parts and tools:
Lights - https://www.amazon.com/gp/product/B07JD8P1VV
Wire - https://www.amazon.com/gp/product/B0799JDF5K
Posi-Taps - https://www.amazon.com/gp/product/B01EINQXEG
Heat Shrink Butt Connectors - https://www.amazon.com/gp/product/B07B518GCJ
Diodes - https://www.amazon.com/gp/product/B007HRO4X8
Heat Shrink Tubing - https://www.amazon.com/gp/product/B075WR9FVL
Crimpers - https://www.amazon.com/gp/product/B0069TRKJ0
Jeep Wrangler JL Backup Lights DiTps
AnthemAVM
Jeep JL
I installed a diode in the engine bay for the wiring running from Aux #4 to the rear and installed a second diode at the top of the rear passenger taillight cavity. All in all, I am very pleased with the results and the increased light at night. Jeep seriously needs to do something about the OEM LED backup lights—tey suck to the point of being dangerous.
Amazing write up
jimmyzwheelz
Jimmy
Little Rock, AR
2019 Wrangler Rubicon 2DR
Thanks for the tip on the crimper tool! I always hated the way my standard crimper worked...this one looks great!
CarbonSteel
It is a ratcheting style and will not let you over-crimp and it also does a "double crimp" about 1/8" apart. For the cost of the Titan crimpers, I am impressed.
blnewt
New Mexico
Just ask @cosine he knows!
@CarbonSteel , great contribution there, way to pay it forward!
Poynter32
Sarasota, FL
2018 JL Rubicon Granite Crystal
