All track bar reinforcement bracket options
Old Jeeper
Don
US Army Infantry, IT Engineer
Agreed! Thanks for the perspective! The one who created the original proof of concept/product to address the identified problem deserves the credit, and the one who improves the product based users feedback deserves continued support too!
It took me back to my TJ build. I had a full set of Dynatrac Pro Rock 60s, Hi Pinion, Hi Steer, ARBs, 4:88s and IIRC 40 spline shafts.
Then I developed DW and what a bitch it was, those heavy axles. When DW began it would shift my front end back and forth over the road.
This was when I decided this engineer was NOT GOING down, I was going to beat DW and I did!
What did I do: Put the Track bar, and Drag link along with the Tie rod parallel to the axle/ground plane and above the axle..
One of the inputs to DW is the angularity of the Track Bar and Drag link.
Cut off the Steering box and Rotate to align the Pitman arm and Drag link.
Cut off the Trackball connection, then fab a new box welded to the frame that drops down to get the Trackball parallel.
Never had DW again in 7 years and almost 80k miles. Note I did change my SS about every other year. I used a Rancho Ford F 450 HD SS. All F 450 was were 4X4 and what front axle did Dynatrac use to build their ProRock 60? Ford F 450!
If I can get out of FL and back to the ranch in Texas I will build another TJR...love my JL but its a delicate Jeep, the electronics are its Achilles heel.
Roky
Roky
I got my synergy brace a few years ago, and it was close to when they first came out. Back then they had trouble with the brass bushing spinning in the housing which would misalign the grease fitting with the hole in the bushing resulting in no grease in the bushing….. I don’t know if I was the first to do it but I fixed mine and about another dozen of them after….. I emailed Dave with synergy and showed him the fix, he said I could’ve just used red loctite….:facepalm: ……. Shortly after that, they came out with a revised version with two set screws in them, a little different than mine but basically the same thing………mine is still working great, but if it ever fails, I’ll likely replace the bushing with the new sealed bearing….
https://www.jlwranglerforums.com/fo...bar-and-sector-shaft-brace.50148/post-1159126
Jeep Wrangler JL All track bar reinforcement bracket options IMG_3361
Fast-n-Furious
Fast-n-Furious
PA
2022 392 XR
Oh man over 20 years you would think Jeep could have totally addressed the DW issue... Maybe that's how we can support the aftermarket companies R&D.
Fast-n-Furious
Fast-n-Furious
PA
2022 392 XR
I appreciate your contribution to the improvement of this product! Many would have just stopped from there and you sir put extra effort into solving the problems for our followers to benefit these days.
Fast-n-Furious
Fast-n-Furious
PA
2022 392 XR
Today I added the Rusty's Front Track Bar Mount Brace into my consideration too, thinking the sector shaft brace may be not really needed since the new JL has cast iron steering box. And I also noticed the center bolt hole that Synergy has too but SteerSmarts doesn't. This design difference makes me think that bolts to the factory bracket for extra strength.
Jeep Wrangler JL All track bar reinforcement bracket options Screenshot 2024-01-09 at 5.14.32 PM
Jeep Wrangler JL All track bar reinforcement bracket options Screenshot 2024-01-09 at 5.15.36 PM
Jeep Wrangler JL All track bar reinforcement bracket options Screenshot 2024-01-09 at 5.16.04 PM
Fast-n-Furious
Fast-n-Furious
PA
2022 392 XR
Noticed this extra backing metal plate, and some members reported install issues and they had to trim that piece with Rusty’s brace. Wanted to post it here to give viewers more info. The early JLs (before 2022MY) didn’t seem to have this piece.
Jeep Wrangler JL All track bar reinforcement bracket options IMG_8522
The Metalcloak brace seems clear this metal piece by looking at the pics from https://www.jlwranglerforums.com/fo...ft-and-track-bar-brace-first-thoughts.123970/
Fast-n-Furious
Fast-n-Furious
PA
2022 392 XR
WFO Concepts also makes a bracket and it clears the extra metal plate. Their bracket uses 3 of the 4 bolts to the steering box, which is less ideal and the two lower holes to secure to the factor bracket may cause binding, possibly due to variations of the welding.
Their version does clear that extra metal piece welded to frame.
Jeep Wrangler JL All track bar reinforcement bracket options IMG_8537
Jeep Wrangler JL All track bar reinforcement bracket options IMG_8536
Fast-n-Furious
Fast-n-Furious
PA
2022 392 XR
I think I’ll go with the SteerSmart bracket (without the sector shaft brace) due to their 4 hole design and 1/4” beefy material. They don’t use extra holes to secure to the factory bracket and this doesn’t cause additional binding force. I may have to trim the extra metal for clearance.
Jeep Wrangler JL All track bar reinforcement bracket options IMG_9347
Jeep Wrangler JL All track bar reinforcement bracket options IMG_9348
Fast-n-Furious
Fast-n-Furious
PA
2022 392 XR
FWIW: More total bolts & different panes likely makes the Metalcloak brace stronger than the fourth steering box bolt.
I don’t disagree. MetalClosk uses 3/16” steel and requires to drill while SteerSmart bracket is 1/4” thickness. Different variables. I bought the SteerSmart bracket without the sector shaft brace, thinking it should be good enough for my use case.
OffRoadPatriot
Keith
Denver, Colorado
2024 392, 2013 JKUR
This is a good thread. For anyone else that finds it and decides to order the Steer Smarts bracket, make sure you get the new version if you have a '24+. The part number is 79041001 and is backwards compatible with earlier years. The earlier 79040002 does NOT fit '24+. Some resellers don't know this (ask me how I know).
Fast-n-Furious
Fast-n-Furious
PA
2022 392 XR
John VonJeep
Middle of Nowhere
Many
Do we have any idea why both they and Synergy are saying these braces don’t fit 2024+? I wonder if there’s some design change, or maybe they just haven’t gotten around to confirming?
JT1
Broken Arrow, OK
2021 Willys Gladiator
There is a reinforcement on the trackbar bracket on 24+ that is in the way of the old style bracket.
John VonJeep
Middle of Nowhere
Many
Thanks. We can add this to the list of small, running changes that Jeep made — but did not announce — for the 2024s.
  • Like
Reactions: JT1
