Zandcwhite
- Zach
- Sep 4, 2019
- Patterson, ca
- 2019 jlur
The engine runs in closed loop and is constantly recalibrating. The manual states 91 octane is recommended under heavy loads and hard use, which I'm pretty sure mountains fall under but yes the Jeep will run on low grade fuel.I'd just stick with whatever octane you normally run. It takes a while for the engine to recalibrate, and the turbo forces air into it, so dropping to a lower octane (like in the carb days) doesn't do much of anything. What I find vexing about gas is the state is still in the carb day and gets lower octane than other states, even though altitude isn't really a factor any more, so mid for us is more like low grade in MO. When we travel I tend to stick with the same octane.
