3.6 power loss at elevation
Zandcwhite
Zach
Patterson, ca
2019 jlur
I'd just stick with whatever octane you normally run. It takes a while for the engine to recalibrate, and the turbo forces air into it, so dropping to a lower octane (like in the carb days) doesn't do much of anything. What I find vexing about gas is the state is still in the carb day and gets lower octane than other states, even though altitude isn't really a factor any more, so mid for us is more like low grade in MO. When we travel I tend to stick with the same octane.
The engine runs in closed loop and is constantly recalibrating. The manual states 91 octane is recommended under heavy loads and hard use, which I'm pretty sure mountains fall under but yes the Jeep will run on low grade fuel.
Remorseless
NC
At least 50 ftlbs at sea level. At 10k feet that jumps to 110 ftlbs, nearly double the 140 that the 3.6L is struggling to put out at that point. What's even wilder is that the 2.0t would be putting out more torque at 10k feet and 2500rpms than the 392. 90% of its 285 ftlbs is still 256.5. 70% of the 392s 350ftlbs at 2500 rpms...245. That's how much of a difference both altitude and forced induction make illustrated as plain as day. Bump that up to 14k feet and I think the 2.0t might actually win a drag race against a 392. So much for waiting for it to "get into" the turbo.
So what you're saying is I'm meeting @DonH63 on Mt Denali (20k ft, gotta make sure I've got a clear advantage - and if there's not a road, we'll make one) and we're dragging for pinks?
Remorseless
NC
Remorseless
NC
Mount blue sky is over 14k and it would be much easier to set up a race there logistically...
Let's be clear here, I'm looking for a race that's so tipped in my favor it's basically cheating.
DonH63
Don
Monument, CO
21 GC Trailhawk, 23 JLU 392 XR
Retired EE; musician (trumpet)
Remorseless
NC
AnnDee4444
'18 JLR 2.0
I'm amused how the 2.0 can simultaneously "take too long to spool" and "get poor mileage because it's always in boost".
I looked into torque converter slip a few weeks ago and noticed the 2.0 has a definite ratio change at 3500 RPM (WOT), and almost locks the converter. I'm thinking that the majority of spooling happens by this point when going WOT from a stop. At speed with a load will spool at a lower RPM, probably around 2500 as shown by the dyno charts
Something interesting came up in this dumpster fire thread: Going off of this video at 14:47 at 0.25 playback speed, I recorded the RPM vs. speed, and was able to approximate torque converter slip. The 2.0 seems to slip the torque converter less starting at about 3500 RPM, while the 3.6 keeps slip at a somewhat steadily diminishing rate.
Don't take this is accurate, a true datalog will likely get better results.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
I think it's just a different discussion when it's "Does it happen" or "Does it matter that it happens".
But, I've also not experienced the 3.6 in the JL at those altitudes. Closest I've come is when I did drive my 3.6 JK from NC to Louisiana and then up through TX, NM, and the corner of CO to get to Moab (had a buddy in New Orleans I met up with and convoyed, thus the ridiculous route), but that's apples and oranges given the 5 speed Merc box in my JK vs the 8 speed in the JL. That JK, with 4.10s and 35s, was chugging along at like 10MPG and the engine wailing with stiff winds in flat ass Texas, so when we hit NM and CO it wasn't apparent if it was to do with any elevation changes or if it just was what it was.
My 3.6L 2020 JLUR was insanely anemic here, but it was a manual. Yeah, I stupidly assumed that Wranglers were like all the other vehicles I bought where the manual was more performant.
Ratbert
PNW
Software Engineer
My experience with my 2 door 3.6L, has been that I didn't notice much difference between where I used to live at 1100 feet (and would regularly drive below that) and where I live now at 5200 feet. However there seems to be a noticeable drop in performance above 6500ish feet.
The slope of the decline is linear. You're apparently just noticing it as the drop in power accumulates.
Ratbert
PNW
Software Engineer
Had to be fun for you back when the Wrangler had 190hp (at sea level).
Reading these forums one might think that nobody in Denver could drive anywhere before turbocharged motors became commonplace. Yet people who live at high altitudes have been towing, wheeling, and racing long before then.
You seem to love to accuse people of using the straw man fallacy, but you might not be aware of the situations where you use it yourself.
DonH63
Don
Monument, CO
I have a 392 so don't know what the manual says for others. I read an article from an engineer a few years ago in some engineering magazine (do not recall which one, was not a car magazine) that said it could take a few tanks of gas for the algorithm to adapt (recalibrate). Feedback from the knock sensors and such will act "instantly" but the power curve algorithm intentionally takes some time to average out short-term variations. I was told the same thing about my 392 when I asked but I'm an EE, not an ME, so rely on others. I do understand feedback. My point was not that it will run on low-grade fuel, but rather that I personally stick with whatever octane I usually run when going on trips. YMMV.
siggy
Kansas City, MO
Fun ones!
Ladies and gentlemen, welcome to the stage, the straw man!
I don’t know this man. I don’t understand this man. All I know is, he makes frequent appearances!
