2.0L Blown at 87K
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
I agree, I would rather the better cooling. Been waiting on a PWM fan controller to be designed for the 2.0 at RPMExtreme but they have yet to have a 2.0 enter their shop.
If anyone with a 2.0 is in their area ill pay $150 towards your controller so that i can get mine before these coming summer months.
http://www.rpmextreme.com/Product/311/Jeep-JL-PWM-FAN-CONTROLLER.aspx
I’d love a fan controller imo, i’m a little anal with my idle times before shutting the jeep off. If temps over 200° i’ll run the heat at full heat and blower and that’ll bring the temps down to 188° in like 2 minutes. It’s a very efficient system if there’s no load. I’d love to have a mishimoto aluminum radiator also but apparently those full aluminum radiators(not specific to mishimoto) crack pretty often from body flex.
Don’t remember where I saw it but apparently our thermostats open at 195° partially and are fully open by 212°.
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
Rogersocal
Roger
2020 Rubicon Recon 2.0 turbo, 2018 Ram 2500 6.7 TD
If I turn my rad fan on full blast I can get coolant temps to 187, never lower. So I'm sure your numbers are definitely close.
But yes, I'm ocd about temps. When I'm running the jeep hard I just keep the rad fan on full and usually run 195 197 coolant temps
The Last Cowboy
San Antonio, TX
2020 JL Willys 2 door
Modern catalytic converters need to run hot, averaging 205 F in order for them to operate at peak efficiency. That's why all engines run so hot these days.
Wylie E. Coyote
So Cal
2023 Wrangler JL Sport Altitude
I simply refuse to buy vehicles with these small displacement turbo engines. There is no way they can last a reasonable 150k+ miles given the weight of the vehicle, all the internal stresses, combined with the type of use we but them through Jeeping. Low speeds, idling, then high speeds in high ambient. These is only so much surface area you can give a four cyl engine to disperse the loads. And, oh yes, let’s put 40s on the rig, too. Fergetit!
That and I didn't want to put premium fuel in it! They said "it's not required", that is until there is an engine problem!
Rick4570
Rick
Virginia
2022 Jeep Wrangler
Lightweight is the key word here. Any time you try raising power output or adding weight, the reliability will potentially go down.
A JL is a hell of a lot heavier than a Subaru type crossover or any other little s***tbox car.
What about the little 4 cylinder turbo engines in the big box trucks? They are hauling 2500 plus pounds up here in the Appalachian Mountains, and let's face it, they are not aerodynamic at all. We see 400,000 plus miles on them pretty regularly.
Alex07
Guest
Alexander
London
2018 Jeep Wrangler
My 18 JLU w 2.0L (Italian origin motor) blew the head gasket at 87. Have the Mopar service contract. Has been at dealer over 2 weeks with no update. Last they said they have to tear down to diagnose whether it needs just head pulled/machined/repaired or new motor. Is this motor going to make it to 200k after repair?
The most important thing is how well the repair is done. If the dealership does a good job and uses the right parts and methods recommended by the manufacturer, your engine can be fixed to work well again. Whether they just fix the head or put in a new engine, how carefully and correctly they do the work will really matter for how reliable your engine will be in the future.
Mudduck
Jay
Michigan
2021 Willys 4door
I had plans to mod my plastic vents, but I like the aluminum ones Motobilt came out with a few months back. No longer being in Texas and putting far less mileage on my Jeep has knocked this down the priorities list quite a bit for me.
Seems heat reduction from opening the vents is mostly anecdotal. There's a ton of threads on it, but I don't know how it could really hurt, especially at idle or off-roading. Plus, my compressor is under the hood, so keeping that cooler is another benefit.
Just installed them myself…
Jeep Wrangler JL 2.0L Blown at 87K IMG_1114
longfiredragon
Darryl
Cocoa Fl.
2021 JLUW Sport 2.0 L Turbo
The 2.0 turbo in our jeeps should easily make 200K. There's some people out there pushing close to that now.
As far as smaller turbocharged engines not running to higher mileage is a total crock of BS! Jeep did not just throw this 2.0 in the jeep and say ok all done. They had specific criteria that had to be meet. Because they knew how people use their jeeps. They tested this engine before hand also. Another good example is the Ecoboost Ford made, they tested it to 250K before they ever released it to the public.
I could go on and on about turbocharged engine's small or big, but I already know from experience on here it's just pissing into the wind. There's just too many people that don't know enough about the subject.
Hopefully the dealership can fix it for you, and if your lucky they might even be able to tell you what caused it. I would be willing to be it had nothing to do with being turbocharged.
Hope it works out for you.
Paluss
maryland
2022 JLURD
One would hope that is part of the Research and Development that makes vehicles so expensive, but in reality, most of that testing is done in simulation, or extreme tests that are suppose to represent thousands of miles.
You can put a vehicle on a track and run it not stop for whatever simulation its suppose to represent. But, it still is not the same as owning a vehicle for 5-10 years of starting stopping, cold weather hot weather, short trips long trips, etc.
If the testing was that thorough a warranty of 10 years or 200k miles would be a safe bet. Unfortunately, the consumer is doing the long term testing, and Jeep makes changes based on warranty claims...
mwilk012
Oklahoma
2018 Ocean Blue JLU Rubicon
Service
The variable is always the customer. People overheat their engines every single day and blame the engine.
MK212MX
Granville Ohio
2021 Wrangler 80th Edition
it’s 1995cc turbo motorcycle engine, pushing around a full-size jeep. No it’s not gonna last 200K as you found out..
The 2.0 motor is not a motorcycle engine, and has no issue moving a Jeep around.
Alfa Romero has been running this engine since 2016, and I'm sure it was tested long before that. The engine has a pretty good track record based on the number of vehicles it is in.
garyji
Gary
Western NC
2017 JK Sahara, 2021 JLU Willys
Haven't read all of it, but you got me at "2000lb camper".
G.
Jeepaddict76
Brandon
2021 JLUR
I’m very happy with the performance of my little 2.0 but don’t expect it to live a long life. Original engine was already replaced at 29k miles. I’ll start looking for a replacement Jeep before I put 80 to 100k on this new engine. We’re expecting these little turbo 4 cylinders to last as long as a NA larger engine and that just isn’t likely.
