XR wheels on JLR
AnnDee4444
'18 JLR 2.0
Prime example is the rear OEM steel bumper.
Virtually all aftermarket bumpers aren't crash tested (AEV is the only one I know of that is). The OEM has vastly different criteria to meet.
I guess "good" is subjective depending on everybody's needs. Sacrificing the Jeep instead of giving the occupants whiplash might be what the OEM intended.
  • Like
Reactions: DGT
guarnibl
Scottsdale / Sarasota
'09 JK, '26 Willys
AEV is the rear bumper I went with... its the only one close to OEM look and feel.
richk225
Rich
New Jersey
2021 392Rubicon XR 2017 Jeep Grand Cherokee
retired due to broken back
I think you may have confused me with someone else. I just mentioned I'd bought takeoff XR wheels for my JLURD.
I actually am purchasing a Clayton lift to run 37's. Glad you recommend it also! And I will be using the Rubicon for what it is wheeling Southern Utah.
I was thinking of you when I wrote my response. I just wanted to throw out there some of the options you have if you want to run 35`s on stock wheels.
You are correct, my mistake. I wanted the OP to know about the options for running a 35" on a Sahara
richk225
Rich
New Jersey
The disclaimer is that OEM Rubicon wheels with spacers and no lift=rubbing issues.
What about if he purchased a take off Rubicon spring and shock setup? Cheap and easy to do and will help with the rubbing and it will give you some lift
Herson
Herson
Michigan
2020 JL Wrangler unlimited rubicon
If it is not a Rubicon, the fenders are already lower so I would imagine that it will still rub. The suspension might help but the other than +45 offset on the rubicon with 35s will rub or even contact the border of the fender if it has to much of a negative offset. You want an offset that the entire tire is stuffed inside the fender wells. This is the first mistake People do when changing the wheels on a wrangler. They put these extreme negative offsets or spacers and then complain that 35s rub on a Rubicon. If it is just for looks and it’s never going to see off-road, then you can get away with it.
Jeep Wrangler JL XR wheels on JLR A0DCBC84-29A5-4186-90DF-5E7112F4BA8A
Cypher
J
AZ
Cybersecurity Leader
I bought a set of XR takeoffs in January also and considered myself lucky to find them. $1300 for a set of 5 with rings and lug nuts.
I wanted a JLUR XR Diesel, but since it's not offered I'm just building my own (with upgraded suspension components). To each their own ?
I also went the do it yourself XR diesel option.
Jeep Wrangler JL XR wheels on JLR 28A1B5A1-9892-4960-89FE-04DAB466DCB7
Jeep Wrangler JL XR wheels on JLR 21941237-0869-4C6B-84C4-2C5F62B91E17
Cypher
J
AZ
They look great on the blue!
Those are some meaty tires. Nitto Grappler 35/12.5?
Actually 315/70/17. the are a smidge wider, but a smidge shorter than the 35/12.5. I wanted wider for sand.
Herson
Herson
Michigan
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
About the only thing I was not happy about when I ordered my '22 JRL was the wheel choice. Why no 'all black'? If this wheel/tire option was available, I'm pretty sure I would have jumped on it unless the price was stupid. Looks awesome!
What is the closest aftermarket wheel that looks like this one?
Bulletbill
Tom
Central PA
2021 JLUR
Just wanted to document this for anyone going with a slightly bigger tire and going for the XR wheels and no lift
392 XR 17x8 Wheels
+12mm offset
Tire: K02 315/70/17
Mounted
Wanted to capture different angels up close and far because that is what usually helps me determine the wheel purchase
Old wheels up for sale https://www.jlwranglerforums.com/fo...at-ko2s-center-caps-tpms-sensors-socal.87778/
Read through but didn’t see this addressed. Did you have to do anything in particular as far as spacing goes? Also since you have had them on, any issues? I love the stance and look but also need functionality.
JLR_AEV
JLR_AEV
2020 Jeep Rubicon AEV Outfitted
What spacing are you referring to exactly? I’ve had 0 issues in terms of rubbing
richk225
Rich
New Jersey
Maybe Backspacing is what he means?
Bulletbill
Tom
Central PA
2021 JLUR
Mostly trying to see if you had to cut or trim anything to prevent them from rubbing. Particularly when you do a hard turn.
My question about having them on long term was more about if the change in geometry affected anything negatively.
I know it’s only about an inch and a half difference in tire size so it doesn’t seem like it should cause any long term problems, but I’ve been leery of just adding larger tires without adjusting the suspension.
