zouch
- Sep 17, 2020
- Berkeley, CA
- XJ, JLUWD
@Wilco7487
how much lift you get from the Mopar "2-inch" lift will vary depending on what configuration you're starting with; the "Mopar Lift" is different for each engine and door configuration.
for example, my Willys Diesel went up over 4" in the front, and under 3" in the rear.
i added a metal bumper and winch to the front and it came out to where i thought it was about perfect,... in height.
as you'll find if you read around on it, some might consider the Mopar lift incomplete.
i found an adjustable front track bar and rear track bar relocation bracket were necessary to get the axles centered back underneath where they belong, and adjustable front control arms very helpful to get the caster to where (i think) it steers better.
i went straight to 35s after this and found that my choice of tires (Mickey Baja Boss MTs) actually rubbed on the LCAs, even (slightly) after i changed to wheels with a more forgiving offset. (bigger tires also probably want a stouter rear tailgate and relocated tire carrier; see how this spirals?)
all that said, i think this setup on the Willys woud be about perfect for what you described wanting to do... but you could probably do most of what you want with a smaller (lighter) tire and not need the spare tire carrier upgrades.
A 2” Mopar lift will be more like 3” on a Willys. Measurements are based on a Rubicon.
