Remorseless
- May 10, 2022
- NC
- '22 JLR 2.0T, '24 JTR, '19 Charger R/T
- Build Thread
- Link
- Occupation
- Holier Than Thou Internet Bully, Part-Time Online Boy Scout, Full-Time Arson Enthusiast, Napalm Compatible, Not Only The Guy Who Defines What A Jeep Guy Is, But Also The Guy Who Defines What A Jeep Thing Is, Guy Who Has The Authority To Do That
With how it bolts down you're not gonna twist much if it's properly seated. Most of the time it goes it's due to the seals against the surface of the block, not due to cracking or twisting. Just straight up the o-rings coming unseated and deforming or seals blowing out (Mopar had to add plastic to support some seals that were basically unsupported in the old design, was stupid, but the redesign is better there). I had the most problematic generation for oil cooler - a '12 JK - for 100k mi. Zero issues with tons of heat (lots of slow 4L wheeling) and oil changes every 5kish miles with the proper torque spec. The torque spec isn't too high, the seal design is/was inadequate. Time will tell if the changes made will remedy the issue.In and of itself, no that's not much. But the torque you impart to the cap goes all the way down to the bottom; you're putting a twist on the whole part, and as it ages and hardens, it becomes less capable of withstanding that torque. Add to that the fact that the plastic is sticky, and requires way more torque to break loose than the 18 ft. lb you used to put it on. (I've measured.)
I will continue to use no more torque than is necessary to seat the O-ring and bottom the cap in the hope that this is sufficient to keep the damned thing from breaking for as long as I have it.
Gawd these things are junk...
