Amciano
- Anna
- Sep 26, 2023
- Rhode Island
- 2024 wrangler sahara
What problems are you referring to with the dorman aluminum housing?The Dorman part comes with its own set of problems, and really isn't a viable solution. This problem is best avoided by just snugging up the filter cap to sufficiently seat the O-ring. Do not torque the cap to whatever insane number they specify in the manual, and DO NOT let the dealer monkey reef on it.
The Dorman housing hasn't kept up with the Mopar revisions to the plastic housing. Mopar keeps revising seals to work better and Dorman is like 3 or 4 revisions behind at this point. Plus, lots of the Dorman housings have casting flash on them that needs to be ground flat for a proper seal. Half ass product IMO.What problems are you referring to with the dorman aluminum housing?
It's 25.5 Nm. It's not an insane torque. 18-19 ft-lb. Basically solid hand snug. Printed on the cap of the housing.The Dorman part comes with its own set of problems, and really isn't a viable solution. This problem is best avoided by just snugging up the filter cap to sufficiently seat the O-ring. Do not torque the cap to whatever insane number they specify in the manual, and DO NOT let the dealer monkey reef on it.
In and of itself, no that's not much. But the torque you impart to the cap goes all the way down to the bottom; you're putting a twist on the whole part, and as it ages and hardens, it becomes less capable of withstanding that torque. Add to that the fact that the plastic is sticky, and requires way more torque to break loose than the 18 ft. lb you used to put it on. (I've measured.)It's 25.5 Nm. It's not an insane torque. 18-19 ft-lb. Basically solid hand snug. Printed on the cap of the housing.
