grandsrus
- Jul 1, 2019
- DFW, TX/ Melbourne, FL
- 2019 JLUR
- Occupation
- Aerospace
Check for loose grounding as well!good idea i will do that...
Definitely getting the right answer from pornhub!!! Also try redtube! They know a ton about Jeeps.can you replicates the problem?
you should video it and put it on YouTube/Facebook/instagram/onlyfans/pornhubs/tiktok with a title like "wrangler 392 engine problem" and get it public, or nobody will help you. Jeep dealer sucks.
my friend's 3.6 auto will just die in 4 low for no reason and no fix either, way passed warranty and dealer just say cannot confirm customer's concern.
will do thanks..Defeinitely getting the right answer from pornhub!!! Also try redtube! They know a ton about Jeeps.
I would look at your battery cables and ensure they are tight.
I would then push in all of your fuses to ensure something is not coming loose during off camber situations. New Wranglers are known for these issues.
GL at dealership.
Man i hope this solves your issue. Lets us know!l wil check them , thanks
will do , i have retighten the battery cables check fuses ,i will take out thisweekend and see what happens...wish me luck..Man i hope this solves your issue. Lets us know!
Did you have any loose fuses? Any push down?will do , i have retighten the battery cables check fuses ,i will take out thisweekend and see what happens...wish me luck..
nope all was tight. battery cables also. grounds that i found were tight.Did you have any loose fuses? Any push down?
playing on very very steep slick hills/banks. my 392 engine will die , goes up the inclines great spinning all 4 tires i get to the top of incline i hit brakes it stops and it will die and i go off the hill way to fast. does in low lock and with lockers or not locked . anyone got any ideas ?
checking in, what is the status?will do , i have retighten the battery cables check fuses ,i will take out thisweekend and see what happens...wish me luck..
He said it was the sensor in the seat belt that was causing his engine to die. All fixed....i hope.checking in, what is the status?
oops, missed that. Thanks and great to hear.He said it was the sensor in the seat belt that was causing his engine to die. All fixed....i hope.
