Sun Visor Fix
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
Thanks for this writeup and suggestions! My son went to flip the passenger side down over the weekend and it just fell out. Mine is a base Sport so I don't have any wiring to contend with, so it should be a simple fix. I have to go to Lowe's for a new basement railing so I'll look for the 8mm collar and fix it up. Will post some pics!
blnewt
New Mexico
Just ask @cosine he knows!
Thanks for this writeup and suggestions! My son went to flip the passenger side one down over the weekend and it just fell out. Mine is a base Sport so I don't have any wiring to contend with, so it should be a simple fix. I have to go to Lowe's for a new basement railing so I'll look for the 8mm collar and fix it up. Will post some pics!
Looks like the FIxer found something to fix :)
The Fixer
North Jersey
Teacher
The Fixer
North Jersey
Teacher
Well, I got my repair done over the weekend. Honestly, the hardest part was finding a hardware store that had the collar in stock; I I think I went to 3 or 4 before I finally found it. Mine was easier since I have a base Sport so there's no harness to contend with. I used a combination of the small cutoff blade and then the sanding drum to get the height where I wanted it. Here's a few pics -
Patient on the workbench for surgery -
Here's the broken end -
I trimmed the plastic end off at the rectangular cutout to expose more of the shaft -
Here's the sleeve on the inside of the trim piece that needs to be cut off -
Here's how it looks after trimming -
Here's how it looks with the collar installed -
blnewt
New Mexico
The Fixer
North Jersey
Teacher
flight4f
MATT
2021 JEEP JL RUBICON
Can you share what collar you got and where you found it? Thanks
blnewt
New Mexico
The Fixer
North Jersey
Teacher
Ah, there it is! 5/16" fits perfectly, that's what I used. The ability to fix the visor for $3 is a win in my book. I bought two because I know sooner or later another one will break - we have two JLs in my house.
The local store I found it in is affiliated with Do It Best Hardware, but I'm not sure if it's a national chain or a Northeast thing. I could not find the collars in my local Lowe's or Home Depot though. Good luck!
four low
central New York
2018 JL
My Sun visor fell down when I turned it to the side, so thanks for this excellent DIY thread. This, and the folding seat problem in the 2 door are the only issues I've had in 18,000 miles with my 2018 2 door Sport. Fingers crossed
four low
central New York
2018 JL
I have a Base Sport, so no wiring to contend with ; only 2 Torx screws on the underside of the visor, and it pulls right off. The hollow tube looked just right for a 1/4 NF tap, ; after trimming plastic as others did, I tapped the tube, found a 1/4 ID washer that fit in the recess, one that matched the OD, and a fiber washer as a spacer. The fastener bottoms out, so no pressure on washers/ spacers. Used JB Weld on the threadedI ID of the tube. A dab of silicone grease on the rotating stem. Not nearly as elegant as some, but surely better than whoever designed the original..
Jeep Wrangler JL Sun Visor Fix PXL_20201124_213809913_resized
blnewt
New Mexico
Jeep Wrangler JL Sun Visor Fix PXL_20201124_211631388_resized
Nice! Seems to be several ways to out-engineer FCA :)
blnewt
New Mexico
JayJay
Johnny
North Georgia
'20 JLR
will this work? its 5/16" bore size
That looks great Kev. Makes it easier on those of us with wiring up to the visor. Any chance that you have an online source?
Later,
Johnny
