Rear Bumper Integrated LED Reverse Lights
rockadile
PA
2019 Mojito! JLUR
Sure feels like Oracle bought the idea from the member who was making the connectors. Pretty odd for him to go silent on us and Oracle to show up with one.
If that’s the case, I don’t know why either party wouldn’t have said anything.
ORACLElights
ORACLElights
Peak Sponsor (Level 2)
Metairie, LA
www.oraclelights.com
2019 Jeep Wrangler JL
Automotive LED Manufacturing
It's a jumper harness, not exactly a novel idea. This type of harness is already made by other companies, we built this because it was requested for a similar product we make for the Gladiator. It happens to work for the JL as well so we can offer it to you guys also. Not sure why the other person went silent, we have no affiliation with anyone else when it comes to this harness.
tatarin
Russ
Bloomingdale, IL
2019 MOAB Mojito Sky One-Touch, 2015 Lexus RX350F-sport, 2005 Camry SE
@tatarin I copied you and put the same tint film on, created a design on my plotter and cut them to shape to make the install easier
It every so slightly reduces the light output, but not noticeable in the backup camera and hardly noticeable if you really look when putting the tint on/off the light from the back of the Jeep
If anyone needs a set of pre-cut tint films shoot me a PM if you need a set cut! It definitely makes the lights more stealth and removes any of the yellowish look the LEDs they have to them when off/in the daytime.
Looks awesome!
mnjeeper
MN
98 TJ, 2021 JLUR
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
@mnjeeper Not sure why the quote is messed up, but you asked:
"Not sure I am reading this correctly. I want to have the same end result. But...you used an AUX with the SPDT? Wouldn't that make it "Reverse Lights", "Off", or "when I push the aux button"? "
And my answer is no. In the passenger footwell are 6 wires. 4 are outputs of the switches, then you have a Constant and an Ignition switched wire. The Constant is 10amp. I have my CB, GMRS radio on the constant wire, and added the Oracle lights to the same wire/circuit.
Hope this helps!
mnjeeper
MN
98 TJ, 2021 JLUR
Hope this helps!
I screwed up the quote trying to clarify only the question. I did great :LOL:
So, you tapped the power, not used one of the AUX buttons. That makes much more sense, and it what I plan to do although I didn't realize there was power for me there.
Bass Fisher
Gilbertsville PA
2020 JLU Rubicon
Ok so I installed the Oracle backup lights. Work great, but I can’t get the little 7mm screw into the back of the lights, no matter what I try. The only thing I haven’t tried is to remove the bumper! Can’t tell you how many thousand times I fished the little screw and washer out of the back of the bumper with a magnet. I dont trust these will stay in place without the screws. Any suggestions would be greatly appreciate.
Dudley Dawson
Northern Virginia
2018 JLU Rubicon
I didn’t bother with those screws - used double-sided tape instead. Perfect fit, snapped in place, (plastic bumper) and they seem very secure.
Mikeyut3
2020 JLUR
We do not have it live on the site yet, however if you would like to purchase you can call in or I can send you a pay pal invoice for this! Please just direct message me.
What is this additional part for? A basic install? Or is for something more complex?
Bass Fisher
Gilbertsville PA
2020 JLU Rubicon
Sent some time last evening and pulled the bumper. Now to decide what to replace that junk splice kit with. solder will be involved. And connectors.
m453w
Ocean City, MD
2021 Gladiator Rubicon
Any updates on when the new harness starts shipping?
Phatm9
Chicago
2018 Sahara Jl- 2007 Sahara Jk
So if I get the oracle harness can I plug it in and the reverse light come on but I can splice into and and run a wide to my auxiliary switch so I can turn it on whenever I want and if so which wire on the oracle harness
rockadile
PA
2019 Mojito! JLUR
Was supposed to start shipping April 10th. I know some people preordered. Anyone get one yet? I don't see them up on Oracle's website.
Phatm9
Chicago
