portable 12 volt air compressor
mikek1971
mike
columbus ohio
wrangler rubicon, grand cherokee and a cherokee
looking for options for having a small non mounted air compressor to have if ever needed to air up a 37 inch tire. don't really do any off roading.
i want to remove spare tire and just need something to air a a flat in a pinch to get to a place to get it fixed. i see several new vehicles do not have a spare anymore and come with a small portable air compressor with fix a flat in them. any recommendations would be helpful and great. i have learned a lot from all of the jeep owners in this forum
thank you
Reinen
2021 Jeep Wrangler JL Rubicon
Hmmm. The problem is a small air compressor and 37" tires don't go well together.
The Viair 400 is an excellent portable air compressor that will handle 37s but it isn't exactly small nor cheap.
Another option to consider since you don't go off road and will probably rarely use the compressor (if ever) is to just get a small cheap compressor and consider it disposable. It will take forever to fill up the 37 and it may burn itself out trying, but as you said it's only for use in a pinch.
rdfact
Ron
Nevada
'21 JLURXR, '01 WJ
Milwaukee and Dewalt make battery powered air compressors.
Smittybilt 12 volt compressors are not too expensive.
Dale's Jeep
Dale
Michigan
2018 Jeep JL 4door Rubicon
Retired U.S. Army 23 years
Harbor frieght has a nice little unit. I've use mine a couple of times works good stock tires though
Mountainwalk
Nolan
Spokane, Washington
2024 Anvil grey JL 3.6 MT, Nissan Xterra Pro4x
The Dewalt is a good option if it’s for topping off tires as condition changes or filling up a low tire. I always throw it in as a back up when traveling but don’t want to bring my heavier compressor. Not great if you are actually airing down but still works just need lots of time to air back up.
Jeep Wrangler JL portable 12 volt air compressor imag
west tex
Skoro
2021 JL 2dr 80th Edition, 2017 Renegade Trailhawk
Retired, as in "Tired again"
I use a Viair 300P and it works like a charm.
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
I have used this compressor for 11 years. I have 35" tires.
Jeep Wrangler JL portable 12 volt air compressor ar
Cips
Anthony
Bucks County PA
2021 Wrangler Unlimited Willys
Sales
I just purchased their 'Maddox' unit and its real nice. I don't have any other to compare it to other than the ones that sometimes come with car. It works for me.
XxTormentorxX
Rich
Chicagoland
2023 Wrangler JL Rubicon XR
I have the EzFlate C.A.S.E. It is a small gun case sized portable twin compressor unit you hook to your battery when needed. It can fill 4 tires at once with their optional 4 tire hose kit.
It comes with a single 26 foot extension along with a 4 foot lead hose so you can set the unit on the ground and inflate your tire.
I am selling mine only because I am going to be installing the Kraken kit and ARB twin compressor next weekend.
Voodooridr
Idaho
2020 JLU WILLYS
I have a ViAir 440P I've used for years and really liked it, my 33's on the TJ and the 35"s on the F250 take +/- 5 minutes. This year I decided I wanted to do all 4 tires at once so I picked up a MorrFlate 10.9 cfm dual compressor and their 4 tire hose now it takes about +/- 8 minutes to do all four
(10psi to 27psi)
Rubi SoHo
Brinton
2021 JLUR-XR
Physician
I’ve got one of those too, it’s good! Might be willing to sell it if OP’s interested since I just got a Morrflate system.
ChoSunJuan
Canada
2004 Nissan Xterra
Viair 400P Automatic. Great unit. Can find cheap on Facebook Marketplace, that's what my friend did and she saved a lot (brand new, never used too).
Bill_BCNtoNY
NY
Ocean Blue JLU Sahara 3.6
Advisor to Boutique Consulting Firms and Solo Practitioners
I bought one of these used, removed it from the box (too bulky for me) and added a trailer plug and anderson connectors to be able to run from either the battery posts or from the 7-pin plug in the back.
made for an interesting project, but I haven’t used it much yet as my offroading plans haven’t materialized for a while ?
Herkder
Randy
Phoenix
2024 Jeep Wrangler Rubicon
I just got a Morrflate with the two tire attachment. I first aired down two of my 37" tires from 32 to 15 lbs and it took 2.5 minutes total. Then I inflated them back up to 32lbs each and it took 2.5 minutes. The compressor was a little warm but not bad at all. Considering it's $300 for both the compressor and the two tire adapter its a good system for the money.
