Portable air compressor recommendations.
bllprk
Kalamazoo, MI
2008 WK CRD
This cheap VEVOR unit.
With a cheap 4 tire inflator setup:
10psi to 30psi - 3 Minutes
10psi to 37psi - 5 Minutes
35" Tires
stretch-bsn
Northern VA
2018 JLU
I have pretty much that exact same one. Name might be different, but they're all Chineseum. It works well, but gets too hot to put back in the bag when done.
Agreed…it does. I normally BS with the group I wheel with for 10-15 minutes after I’m done airing up and that tends to cool it down enough to pack away.
Pape
Quebec
JLU Sahara
A compressor is a compressor, to each it own. Got one of the Via Air, I do not recall exactly I think it is a 400c, I run the crap out of the thing filling repurposed propane tank up to 150 psi. Probably overstepping the duty cycle it is rated for and still going strong 10 years down the road.
PhrogUSMC
Edwin
Virginia
'21 JLUR
I've been wanting to go onboard. My gf's Gladiator has onboard ARB setup that she'll never use. I want to migrate it to mine, but previous owner has air lines and relays all over the engine bay and throughout the Jeep that It's pretty much a permanent fixture now. Lol
Maybe I'll just get a 4-tire fill system to adapt to the portable compressor.
Grey24Rubi
NW
2024 4dr Rubicon
I bought the new ARB twin brushless portable kit shortly after it became available and I've been very impressed with it so far. Are they more expensive then most yes they are but, damn, are these things fricken fast.
I like the portable kit for the obvious reasons of using it in different vehicles. I throw it in the trailer when we take the SxS and it is a pretty convenient item to have.
Upnarms
AZ
2019 JLUR, 2003 TJ X
The morrflate ones are insane. As another person says, i think these are for the most part the same under a couple different brands (thors, etc). There is a 5.6 and 10.6 available. The 10.6 isn't recommended for single tire inflation. We have the 5.6 and it's still crazy fast. You can find youtube videos where it beats even arb dual in inflation speed at half the cost (or less).
CapeArt
BB
Cape Cod
2023 JL Sport S, Porsche 987S, MazdaSpeed Miata
I’ve been using Viair 400P Automatic with MORRFLATE 4-tire kit & it’s been great - highly recommend
Sandevino
North Texas
2025 Wrangler Rubicon, 2002 Wrangler X
Rubi SoHo
Brinton
Utah
2021 JLUR-XR
Physician
I use a morrflate 4 wheel system and dual compressor. It’s perfect, and gets my 37’s filled back up quickly
F4Flyer
Littleton
2024 Rubicon X
There are three I would buy:
ARB Twin Brushless
ARB Twin
MORRFLATE
The first two are awesome and proven. The MORRFLATE pumps are newer but also proven and MORRFLATE gives back to the community for trails and trail access. They give back quite a quite of their profits. That is it. I'd buy nothing else. I have the ARB Twin and the MORRFLATE 4-hose system.
AZJLguy
Logan
Maricopa, Arizona
2025 Rubicon X
Mikey T
Jeep Wrangler 392
I have the same one and it has been flawless. I air from 10lbs to 35 lbs on my 40's in less than 10 minutes.
