OEM Steering Stabilizer Issue understanding label
YBABRAT
VIRGINIA
2019 2 Door Rubicon X Wannabe
None... but it pays well.
Alright, from what I see... the label seems to show front is back. Is this OEM steering stabilizer installed correctly?
Jeep Wrangler JL OEM Steering Stabilizer Issue understanding label 1000040228
The label is located at the right side near the steering knuckle.
Jeep Wrangler JL OEM Steering Stabilizer Issue understanding label 1000040226
The Fixer
North Jersey
2018 Mojito! JLS, 2018 Firecracker JLUSS
Teacher
Looks backwards to me, though I honestly don't know if it makes a difference. The shock is still horizontally mounted in either direction.
YBABRAT
VIRGINIA
Thanks... after intensive search for images of factory Rubicon suspensions, there are a few with the stabilizer in opposite direction. Though mine has label facing up, not down as many are pictured. If I rotate the stabilizer 180° to have the label face down to the road, there is no question as to the installed orientation.
~Blue392~
Maryland
2022 Jeep Rubicon 392
It’s probably because of the cover over the shaft. In the current position when the tire kicks up water and debris it could get between the cover and the stabilizer body. Flip the stabilizer around 180 degrees and the cover is doing its job. Probably nothing to worry about. There are thousands of Jeeps out there with stabilizers that don’t even have covers of the their shafts. (That sounds really bad. I’ll wait for the jokes :))
Speed331
Sean
Las Vegas, NV
2008 Jetta, 2018 Discovery Sport, 2020 Wrangler Sport S (on order)
No need for a cover, a properly tight seal will keep your shaft nice and shiny...
Jeep Wrangler JL OEM Steering Stabilizer Issue understanding label 20241111_052353
c20040215
Leon
Should I take my pants or shirt off first when taking a shower?
I dont think it makes any difference one way or the other. :CWL:
AnnDee4444
'18 JLR 2.0
From another thread:
Shocks work by oil through an orifice. Oil can’t compress so the orifice slows things down.
Gas compresses so it all goes right through an orifice very easily and you loose the dampening effect.
So it’s important to keep the orifice side down where the oil is.
YBABRAT
VIRGINIA
Camaroboi13
Justin
San Bernardino, CA
2022 JTOD, 2024 JLU W
LEO... life in Chino
My wife had her 2018 JLU stabilizer replaced under recall. When I installed a Fox stabilizer 6 months later I found that the dealer installed the new factory one backwards. Either they’re idiots (likely) or the orientation does not matter.
