Jeep Jacks
Heater
TX
2017 Ram Power Wagon, 2009 JKU Rubicon 392 AMW, 2006 LJ Rubicon, 1984 CJ-7.
USN Retired PAMO
VKSheridan
Vince
Broken Arrow, OK
2020 2 Dr Rubicon JL Hardtop
I use an air bag as my jack. I can fill it with my compressor or my exhaust. It works in pretty much all ground conditions and can flip a Tundra back on its paws. It’s good for recovery and (softly) getting a high centered or side centered Jeep back into the game
Jay_Jeep
Jay
2023 JL Sport S 2 Door
Guess i will get one of those AEV blocks, I appreciate all the information!
I bought one of those after having to change a tire and having to locate a flat rock to put under the jack. Pretty sketchy with the rock but got the job done. I decided I’m not gonna try my luck a second time in the future so I bought that AEV block and it does store nicely out of the way.
Eyeball
1997 TJ & 2023 JLUR
Instead of the AEV overpriced piece of plastic and a sketchy scissor jack look into something like the safe jack
https://safejacks.com/collections/bottle-jack-accessories/products/basic-bottle-jack-kit
Safe Jack is expensive but has some nice stuff. I do not carry a bottle jack but my experience on the trail with those that do often begins with an inoperable fluidless jack… The lower cost ones like Harbir Freight are notorious for losing fluid when stored in less that perfect conditions. Maybe the safe jacks with their higher cost and hopefully higher quality have overcome this drawback.
Nitehawk92
Vandalia, Ohio
23 JLU Reign Rubicon 14 Mazda, 22 Hyundia Santa Fe
Retired Air Force Current Civil Service Civilian.
Use a sharpie and write Jeep on it…then maybe?
If he writes Jeep on it he will have to sell the wood for at least $100...
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
jeez are you serious to buying a $80 plastic block?
just get a piece of 2x8 wood from home depot. cost less than $5 and you can make probably 3 out of it.
Yep, sometimes some of us are willing to pay quite a bit for something that takes up zero usable space. Fortunately mine was only a $43 option when I bought my Wrangler.
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
I carry a Hi-Lift farm jack bolted onto my rear bumper skid, and I have permanently attached a farm jack base plate to it, like the one @Roky showed in his previous post.
I don’t recommend this if (a) you don’t know how to safely use it (including what contact point on the vehicle to jack from); (b) cannot efficiently and safely store it (loose in the back of a Wrangler would be a nightmare in a rollover accident); (c) cannot physically handle its weight. Also, you must keep them lubed so they function properly. I always carry a can of Break Free, or a similar product, in my gear bag, and I periodically spray the mechanism with it.
Jacking up a vehicle will always have safety issues, regardless of the jack used. Farm jacks are no different. The key is to loosen your lug nuts before jacking up the vehicle, jacking it up just barely high enough to install the spare tire, and installing the lug nuts snug - but don’t torque them down until the vehicle is back on the ground. Just make sure the spare is fully seated before lowering it.
I avoid having to crawl or reach under my Jeep unless absolutely necessary - I’m too old for that crap! - thus the farm jack.
ParadigmDawg
Greg
Fort Worth TX
I have one of these in my Jeep and one in my truck. Amazon and Tractor Supply carry them. I keep the one in my Jeep in a plastic milk crate which also holds the handle, gloves, etc.
https://www.amazon.com/gp/product/B00GJJZ5NI/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Powerbuilt 3 Ton, Bottle Jack and Jack Stands in One, 6000 Pound Capacity, All-in-One Car Lift, Heavy Duty Vehicle Unijack, Wide Base
I also carry this and a bottle jack in my 392. I guess counting the stock jack, I have 3 jacks in it...lol..
These are nifty.
Chinese sourced ARB style hydraulic ram jack.
Jeep Wrangler JL Jeep Jacks 20240130_150349
Pro Eagle 1 1/2 ton is pretty small and not much more weight than a HiLift.
Jeep Wrangler JL Jeep Jacks 20231204_122448
Jeep Wrangler JL Jeep Jacks 20231204_122217
24" scissor jacks fitted with frame and axle saddles.
Jeep Wrangler JL Jeep Jacks jack scissor
Harbor Fright 3 ton aluminum floor jack fitted with extensions
Jeep Wrangler JL Jeep Jacks new jack2
Jeep Wrangler JL Jeep Jacks new jack3
Fast-n-Furious
PA
2022 392 XR
Gortech Jack. Threw the OE Jack in trash, my wife’s Audi A4 Jack is even beefier than jeep’s.
Jeep Wrangler JL Jeep Jacks IMG_9606
Medsker
Jon
South Jordan, Utah
I carry one of these and a piece of LVL beam material for a stable base.
Jeep Wrangler JL Jeep Jacks 1728374931468-3s-jpg
This is what I carry too. I still have the factory scissor jack with the spacer that came with the XR package if I need a backup.
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
Which one do you use? I like this idea, takes up less space, no fluid to fuss with like bottle jack
