Fobless key
smithrd65
San Antonio
2018 Jeep Wrangler Rubicon Unlimited JL. BMW Z4 35is, Tesla Model X90D, Chevy 2500 LTZ
Sounds like someone who is far behind times. No key fobs are anything seems to be STONE AGE THOUGHT PROCESS.
The JL is an genuine Jeep no matter how much electronic devices they install. Its modern. Jeep had to move forward with technology.
Its life.
And no its not Suburbia at all its what it is modern day. And I want speak on beer I don't drink so each his own.
smithrd65
San Antonio
I like the key Fob, but again I guess I'm custom to holding large items.
Jebiruph
Jebiruph
Jerry
Iowa
2018 JLU, 2020 JT, 2024 WL
I disassembled my fob to release the spring tension on the blade and noticed that the top of the blade already has hole and could be put on a key ring as is, if someone didn't want to mess with getting an additional key cut.
Jeep Wrangler JL Fobless key fob guts
old8tora
Cali
2016 JK Sport
But will it work whilst detached ? What is with the Continental logo ? That is a German tire company .
WranglerMan
Will
Greenfield Indiana
2018 Wrangler JLU Sahara
Why would it not work while detached, it’s not a chipped key.
old8tora
Cali
2016 JK Sport
Well , some posters above # 48 ( @SupChic ) said it did not work whilst detached . ( You gotta love it : buy a new Jeep and then you are required to become an electronic locksmith just to get in . ) Then # 50 @nvabill said to use a pair of pliers . ( A non-electronic solution .)
Also , others report that the special electronic code tag is somehow missing . Likely some dealer turd took the code tag , for reasons of stupidity or maliciousness ? Who knows ?
Jebiruph
Jebiruph
Jerry
Iowa
Not working whilst detached is mechanical not electrical, you need some way to apply torque to the key. The first ring I put mine on was too small, after I put it on a larger ring it was easier to use.
WranglerMan
Will
Greenfield Indiana
Well , some posters above ( @SupChic ) said it did not work whilst detached . ( You gotta love it : buy a new Jeep and then you are required to become an electronic locksmith just to get in . ) Then @nvabill said to use a pair of pliers .
Well I could see having to use a pair of pliers or similar, I popped out the key from the FOB and tried it in the door and it’s pretty stiff to turn so I can only imagine it would be a huge pain to try and hold in your hand and try to turn in the lock.
old8tora
Cali
2016 JK Sport
How about rigging up a small socket wrench ? You could use it to turn the key both directions .
WranglerMan
Will
Greenfield Indiana
Having a spare key is nice but your still going to need a FOB to start the Jeep so if you lose the FOB and have a spare key on the Jeep you can get in but unless there is a spare FOB in the Jeep your not going anywhere so I am having a hard time figuring out why the spare key.
Akbill
Bill
Alaska
'19 JLUR
Ok, I went to the locksmith today. He was able to cut the JL key!
He also drilled a hole in the key shaft for a key ring.
All local Jeep dealers and locksmiths said no way could they cut the JL key for me. Said I would have to get cut by Jeep (not at a Jeep dealership) using the Vin#.
I had two done. Total was $54.95 with NYS tax. I gave the guy $60. So, the two blanks purchased on eBay that were $8.63 + the $60 cut fee, ends up being $34.31 for each key. Of course, I had to drive 45 mins to the locksmith and back.
eBAY key blank I used. You get 2 for $8.63:
https://www.ebay.com/itm/New-Remote-Emergency-Key-High-Security-Replacement-Blade-Insert-for-Fiat-Jeep-P/272991903692?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
For those in NY, Liberty Locksmith in Liberty, N.Y. cut the keys.
Anyway, I'm all set now. One key is stashed on JL.
ebay can't find that key now. There are others, but I am not sure which one would work.... Anyone?
this is all I can find today
https://www.ebay.com/itm/5X-New-Rem...h=item2aa6c56078:g:MywAAOSwAFFcELuH:rk:1:pf:0
Jeep Wrangler JL Fobless key s-l225
Akbill
Bill
Alaska
'19 JLUR
@Akbill
You need a blank for: 2016 Jeep Fiat High Security Emergency Key
Look here. Description says it is for a pair of 2016 Jeep Fiat High Security Emergency Key's
https://www.ebay.com/itm/NEW-Set-Of...ZHySj:sc:USPSFirstClass!12571!US!-1:rk:1:pf:0
Thank you. ,
yes it says fiat Jeep 2016 model renegade,
and in compatibility I get this:
"This part is not compatible with 2018 Jeep Wrangler Unlimited Rubicon Sport Utility 4-Door 3.6L 3604CC 220Cu. In. V6 GAS DOHC Naturally Aspirated", but you think this will work in the JL ?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Thank you. ,
@Akbill
Well, I will not put my neck out and say the blank will positively, do the deed for you. I believe it will based totally on that the description says it is in fact a 2016 Jeep Fiat High Security Emergency Key and that is what you want.
You could reach out to the seller and ask is this in fact a 2016 Jeep Fiat High Security Emergency Key
Positive thing... seller is in the USA
