Fire Extinguishers
Old Jeeper
Don
US Army Infantry, IT Engineer
I like the Rugged Ridge mount. It holds a 5lb extinguisher to the rollbar conveniently inside the tailgate.
Lookin GOOD & Ready!
Roky
Roky
I don’t get all the “easy to clean up “ there’s so much plastic on these rigs, you’re gonna end up with this ? in a matter of seconds so I think cleaning up would be the least of my worries……?‍♂
Sand Flea
Kevin
Lewes DE
2025 JL Wrangler Unlimited, Sahara
Federal Firefighter, Retired
Larger one mounted in the garage.
Jeep Wrangler JL Fire Extinguishers IMG_2841
roaniecowpony
roaniecowpony
Retired Engineer
Then I have no inclination to carry an extinguisher. Burn baby, burn.
paffemt
Chester County, PA
2019 JLU Sahara
Was that in reference to my comment about using a BC for a kitchen stove fire vice an ABC?
Roky
Roky
Nah dude, it was a generalization, of all the posts, I don’t even know what BC and ABC is…..?
Deleted member 59498
Guest
I would keep one to protect a person from getting harmed or try, but if the jeep catches on fire evacuate and well so long old friend!
  • Like
Reactions: AFD
Sand Flea
Kevin
Lewes DE
Class A - ordinary combustibles. Wood, paper, cardboard, vegetation.
Class B - hydrocarbons. Gas, diesel, oil.
Class C - fires in 'energized' electrical equipment. Take power away and it becomes an A or B fire.
Class D - combustible metals. Magnesium, lithium, phosphorus, etc.
rcc1123
Rick
Arizona
2019 JLU Sahara
Out of curiosity, for those that keep them on board all the time, is there a concern that heat built up inside the cabin on a hot summer day with the windows closed might trigger one of these to blow and douse the interior?
I'm in Arizona and it's 118 degrees f today. I have had my extinguisher mounted on my roll bar for 4 years and it's still charged well. I have an ABC type that should cover all fires well.
zouch
Berkeley, CA
XJ, JLUWD
i chose a Halguard (mounted on the rear roll cage because that's closest to where we cook at the tailgate), mostly because i didn't want to use a dry powder that would damage the electrical insulation if ever i needed to use it under the hood.
some chem extinguishers can save you from the fire, but leave you with a harness that's so thrashed the vehicle is effectively totaled anyway.
mnjeeper
MN
98 TJ, 2021 JLUR
I was considering buying the Element extinguishers until I watched a few you tube videos. They didn't seem very effective and you need to be too close to the fire. I don't think they will work well in the real world.
I'll be honest. I am really disappointed. I was going to get one.
roaniecowpony
roaniecowpony
Retired Engineer
Yeah, the footprint is incredible. But apparently it aint all it claims.
I'm heading to a machinery salvage sales yard today. Rumor is there are some small Co2 extinguishers there.
MrMischief
JL Rubicon
I'm not concerned about putting out non-vehicle fires.
I have the exact opposite opinion. If my Jeep catches fire out and about somewhere, assuming nobody is trapped in it, I'll get what I want/need out and just watch it burn as I wait for the fire department who is better equipped to deal with it than I am. I just have the theory that my 5 lbs extinguisher is not likely to put that fire out and I doubt I want any vehicle after it has been on fire anyways. My extinguisher is to save the forest, not my Jeep. Extinguishers are handy to have, but I think the idea of noticing smoke from under your hood, grabbing the extinguisher, and putting out the fire is not very realistic. It could happen, but not likely. The most I've used my extinguishers over the years is putting out unattended camp fires that I come across.
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Was successfully able to put out an engine bay fire with my last car using an extinguisher. Had some critters build up some nesting material on one of the heat shields above the turbo and by the time I got to work, the heat turned it into flames. Thankfully, the fire was still contained to just that section and no other damage occurred, but had it spread any further and started to melt all the countless wiring harnesses, I probably would've been better off to just let it continue burning while calling the fire department. Getting something like that repaired likely would've been a nightmare.
