- Elliot
- Mar 9, 2022
- Athens, GA
- 2019 Sahara
- Banned
Love it/hate it, either's fine by me.
Love it/hate it in the JL, either's fine by me.
Research shows it saves gasoline. Small amounts yes.
So...the engine stops at traffic lights and vehicle appliances run off battery power, saving gasoline, hopefully more so than any additional fuel to get the engine going again--the so called 7 second rule of ESS savings. That's the easy part.
But---that depleted battery from the ESS event has to get its energy back from somewhere, in this case an alternator, dependent on a gasoline powered engine, which presumably has to work that much harder to torque an alternator under greater load, to turn the mechanical energy of the engine into electrical energy and then into the chemical energy of the battery in need of post ESS event recharging.
I remember science lessons on how conversion of energy from one form to another loses energy from a closed system, and here where going from the chemical energy of gasoline to the mechanical energy of an engine, to the electrical engine of an alternator, to chemical energy of a battery.
So--as I see it, the way this system saves gasoline must be that given all the gasoline to get an engine up to speed, the additional or marginal extra gasoline for the running engine to torque that smart alternator beyond what it would require when the batteries are charged, is less than the gasoline savings of turning the engine off at stop lights. In fact it is so much less that we're even saving (small amounts of) gasoline despite the conversion of chemical to mechanical to electrical to chemical energy of the post ESS event battery recharging process.
How do I explain this to a middle schooler? Do I say that there are enormous economies of scale to get a car engine going such that torqueing an alternator for an already running engine is a "child's play" additional energy load in terms of the additional gasoline consumed? It's not as if other sources of energy like regenerative braking are being used in the JL (yet) to recharge an ESS battery.
Thanks.
Thanks.
