Sean L
- Sean
- Mar 9, 2018
- North Carolina
- 2018 JLU, 2017 Honda Accord, 2014 Yamaha XVS 1300
- Occupation
- Retired Marine, Construction Estimator
- Vehicle Showcase
- 2
After driving my Jeep for these past few weeks and getting to learn how to work ESS.
First off, ESS will not auto stop your engine until it is at operating temperature so no need to worry about it until its warmed up.
Tips:
1. The auto stop is sensitive to your brake pressure. When you approach a stop sign or some other quick stop where an auto stop isn't necessary, use light brake pressure to avoid an auto stop when your going to immediately move after stopping.
2. Use medium brake pressure to initiate an auto stop when you're at a red light or stop sign where you wait for traffic or drive through window.
3. The engine will restart when you start to lift your foot off the brake, so keep a consistent brake pressure to avoid an unnecessary restart for the duration of the red light.
4. Don't have your A/C cranked to maximum. This will cause your ESS to keep cranking your engine several times at a stop light and will get annoying pretty quickly. I use my automatic climate control to keep a comfortable temp and it doesn't start the engine unnecessarily.
5. In heavy stop and go traffic, just disable the ESS. Chances are you'll only be stopped for a second or two and the ESS will drive you insane.
6. Shift into park quickly.
Anyone else have any tips that don't involve a big Grumpy Cat response?
Tips:
